please help, i'm worried
Old October 21st, 2007, 02:25 AM   #1
89lx5.0 is on a distinguished road
okay, here is the problem, i have a 89 LX 5.0 with a 5spd. recently the oil pressure gauge started to drop to nothing (stock gauge) when i come to a stop not immediatly but after sitting for a few seconds.... well sometimes immediatly. however when i am cruising along and push in the clutch and just let it coast it doesn't drop. also sometimes when at a stop it will drop down then jump right back up after a couple seconds.... also when i say drop i don't mean like slowly i mean like i just turned off the ignition kind of a drop, and i mean ALLLLL the way down, like when the car is off.....
PLEASE help me, and fast this is my only car right now.
Old October 21st, 2007, 02:36 AM   #2
baine21225's Avatar
get a new gauge, it would be nicer anyway
Old October 21st, 2007, 03:38 AM   #3
you think it's just my gauge? i hope your right. should i go mechanical or electric? if i go mech, it needs to be mounted outside the car right?
Old October 21st, 2007, 03:40 AM   #4
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Mechanical does need to be mounted outside. Go electric. But I dont think its only your gauge but I dont know exactly what it is. Start with the gauge and go from there though.
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old October 21st, 2007, 06:13 AM   #5
you think maybe the oil pump? ....please say no.....god i hope it's just a bad gauge
Old October 21st, 2007, 07:53 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'd check it with a different gauge. If it still does it, then its time to worry.
Old October 21st, 2007, 08:39 AM   #7
1990 hatchback lx
Twist it up is on a distinguished road
Send a message via Yahoo to Twist it up
hook a manuel gauge in the sending unit port and check it that way, my street car does that but it runs rich all the time..... not good on cylinder walls.....
www.hsvracing.com
Old October 21st, 2007, 05:06 PM   #8
vfast will become famous soon enough
mechanical gauge can be safely put in the cockpit..I use a copper line instead of the palstic one
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old October 21st, 2007, 05:57 PM   #9
ymerej47's Avatar
ymerej47 is on a distinguished road
Mine does the exact same thing
even tho ur engine is 2x bigger I dont think it matters
Mine has a mind of its own and Ive been driving it for a while what I did was
cleaned the engine bay to check for leaks...checked the dipstick regularly like everyday...
and then I checked for enlarged/dilated hoses and the ones I found I replaced with steel braided (2)
and my gauge still goes haywire so Im pretty sure urs is the gauge also
1989 Mustang LX Hatch
2.3L - Custom CAI, Flow40 w/custom exit, V8 is coming after appearance mods.
Old October 21st, 2007, 08:53 PM   #10
Speedstang302's Avatar
13.64@101mph
+1 copper line is ALOT safer
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 21st, 2007, 08:54 PM   #11
13.64@101mph
i say if its the gauge...than electric and autometer ONLY!
Old October 21st, 2007, 08:57 PM   #12
darkest hour's Avatar
darkest hour is on a distinguished road
Im just going to ask something stupid, but have you checked the oil level?
Old October 21st, 2007, 09:36 PM   #13
NYHigH's Avatar
NYHigH is on a distinguished road
I'd bet on that it's the sending unit. My truck was doing the same thing. When i went around corners or came to a hard stop the guage would shoot back up. It was doing it for a while to, until i decided to do the easy thing first. Go to autozone and spend $30 at most for a new sending unit. Worked fine after that.
Threads Similar to: please help, i'm worried
WORRIED criptez V6 Mustangs 12 June 5th, 2007 10:22 AM
Please tell me this is nothing to be worried about! amphibrecon 99-04 21 March 27th, 2007 05:36 PM
