Discussing Brakes question in the 5.0 Mustangs Forum. What all do i need to do the brakes on my 92 LX 5.0 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Brakes question
i just need to change the pads in them and get the rotor machined. and i want to do them myself. anything else i need besides the pads and take the rotors to get machined. do i need special tools?? do i need to bleed the brakes??
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
Maintenance Man
11.47@120.58
No special tools, you don't need to bleed the brakes. You'll need a c-clamp to push the caliper back in and some anti-squeel compound to put on the back of the pads (unless they come with shims) to keep them from making noise. Might be a good idea to get a can of brake cleaner too.
ok. so i dont need brake shoes. just need the pads, take the rotors off and have them machined, c clamps, anti squeel compound if they dont come with shims brake cleaner???
ok well i got the pads. there 100 % shimmed.
im so weary about doing this. never did it before and it's brakes. i need to be able to stop. lol. and i want to do it my self. anyone know where i can find some detailed instructions. im a little timid about doing it and all the help i can use is a good idea.
if u need any instructions go pick up a chilton manual.
ahh yes. i forgot about them. good idea. thanks
yes they come in handy all the time
get a good machine shop to cut the rotors...not a-zone or pep boys. they WILL ruin them
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
when i did mine i got new rotors, it was not to much money
Sometimes removing the caliper pins is tough if they are seized/rusted, you will break your torx bit everytime, buy the type with a lifetime guarantee, if you break it just take it back. You may need to heat the caliper bracket where the pin threads in to loosen it, if you heat and apply some pressure you will feel the caliper pin come loose. Just don't torch the caliper rubber dust seal. I've got away with using a Plumbers Propane torch for years on these. Even better is having an impact gun.
Don't be discouraged we have all felt nervous doing it the first time. Good Luck |
yeah i know about that breaking the torx bits. i broke 5 of them just trying to get my manifold plate off. what a bitch. i got to buy them in bulk seems like. so i got them soaking in penetrating oil. hopefully i can get them off. i dont know my own strength sometimes.
Threads Similar to: Brakes question
| Brakes, Which To Go With? | energiesource | 99-04 | 15 | December 25th, 2007 12:27 AM |
| wat brakes? | VSR13 | V6 Mustangs | 11 | September 27th, 2007 02:41 AM |
| BRAKES!!!!! | mustang500hp | 96-98 | 7 | April 16th, 2007 06:40 PM |
| Brakes! | mustangstud13 | 99-04 | 2 | September 10th, 2006 12:21 AM |
| Brakes | WeCircleTheProblem | V6 Mustangs | 5 | July 31st, 2006 01:05 AM |
