![]() iTrader: 1 reviews
Turn signal help
Can anyone help with my turn signals?I checked the fuse and I changed the multi function switch but the turn signals still don't work.Everything else is working,flashers,hi beams and flash to pass.Is there a relay somewhere for the turn signal?
91 LX coupe,Aluminum heads,Steeda roller rockers,Typhoon Intake,F303 cam,Cold Air Intake,Tremec T5, Cobra R Rims, MSD ignition, MSD distributor, FMS Cobra LSD w/3:73 Gears and 31 spline axles. |
1988 Mustang GT Vert
Did you check the turn signal flashers? It's located on the center console dashboard reinforcement panel its above or below your radio on the plate that's there, do they turn on at all or no?
No they dont work at all.I will check that tonight.
No, that is why I changed it.
duh
the wires that go into the back of the plastic the connects t the bulb get loose sometimes and you have to jam them back in, happaned to like 2 months ago
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
soon to be fox body
check the turn signal relays
starting from scratch |
whats a" custom cluster fuck" ?
"supernatural aspiration" |
1987 ford mustang gt
well see when shes done
custom guage cluster look at florida5.0.com
soon to be fox body
they are a little on the high side in price but worth it
If it was wires at the back of the bulbs wouldn't some of the turn signals work?None work on mine at all.
Which ones are the turn signal relays?There are 3 or 4 under the dash.
95 Mustang GT
Try adding blinker fluid.....sorry someone was going to say it
1991 FORD MUSTANG GT
i need help with a turn signal problem . ive replaced the flasher behind the console and my fuse still is blowing out . when i turn on the key my turn signal fuse blows out
#16 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
notice the color of the wires and make sure you get the right one. There is another flasher that looks the same but it goes to the hazards on the back of the fuse panel.
1982 GT t-top
no proof of purchase
You probably have a bare wire somewhere shorting it out
Threads Similar to: Turn signal help
| Turn Signal | MnrlGry01gt | 99-04 | 13 | October 16th, 2010 06:18 PM |
| Turn Signal | Youngin | The Clubhouse | 11 | August 18th, 2007 10:20 PM |
| turn signal? | thatonekidw/theGT | Modular Mustangs | 3 | July 22nd, 2007 06:39 PM |
| Turn Signal | CBSTANG | 99-04 | 9 | May 28th, 2007 12:38 PM |
| No turn signal | ByPopularDemand | V6 Mustangs | 37 | May 24th, 2007 08:53 PM |
