Stock 302 H.O Head questions
What up people i own a 1993 mustang gt and i have a pair of 351c 2 bbl heads. Is there any way I can make them fit?
I also have a 351c 4 bbl heads with a c6 trans. Is it hard to swap it into my fox? What will i need to get this to work? or should i just port the stock heads/ intake and go with a small cam? The car right now as is did a best of 14.3 with a stock engine and a crappy run.
![]() Stock 5.0 Engine M/T Drag Radials E.T.- 13.859 MPH-97.23 60 foot-1.853 |
soon to be fox body
a c6 trans is not a good idea there is alot fo modifing and different starters and too much shit. c4 ftw
starting from scratch |
#3 | |
13.64@101mph
Sell it?! No way. I love the sound of it.
Big timin' in a small town
No sell your 351 heads and your c6 and get a trickflow topend kit much better than 351 heads
#6 | |
13.64@101mph
sell your 351 heads, block and c6 and get top end kit or just h/c/i
.........wow Beeing called stupid by a pair of e-tards hurts.
![]() There is no way I am going to sell my 351c. Its the same engine that was in the Pantera, and the engine that came in my 1970 Mach 1. and to sell that would just be plane stupid. What i want to know is what would i need to to to make this engine. ![]() replace this enigine. ![]() OR if it is possible to replace the 302 heads with 2 bbl heads out of a 351c
any big block heads will not fit a small block if thats what your asking.......and as far as putting the whole 351c in your mustang wont be just a drop in type thang.......there will be significant modding.......if you are looking to get the extra cubic inches you could go with the 351w which is a small block and takes minimal changes to putt in a fox
#9 | |
1987 ford mustang gt
well see when shes done
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
asking for help from "e-tards" seems hypocritical, don't you think?
#11 | |
#12 | |
i know what he said but why did you say that??????????????????/
when you call someone an "e-tard" and then ask for help...
nevermind.
but putting those kind of heads on it doesn't seem sensible.
48.47@ 12.58
I Understand you Ron.
it's cool
Thanks Jordan and Iwannagofast for the informative replies.
Five cent your opinion no longer matters. I am going to go out and look for a 351w. Will I be able to reuse the T-5?
#19 | |
1979 mustang 5.0
hopefully 11's when complete
Ok screw the c-6 first off! that's a ton of modding and automatics (unless in a dragster) are for pussies, everybody knows that........
You CAN put 351c heads on a 351w I know. guys used to do it back in the day, but don't ask me what they did to the block or what the hell they used for an intake manifold..... They probably had to customize a lot of shit! Trickflow makes the best heads, there the way to go. If you want more cubes build a 351w like I did..... Don't get me wrong unlike a lot of the guys here I love big blocks, but putting one in a fox body just to get the same displacement you can get from a SB dosn't make sense. As far as the T-5 goes with the 351w it all depends on how much you build the engine and what your going to do with it. A ton of guys will tell you "I built an engine with as much power as yours and used the stock t-5 and I was fine....." but then ask them if they ever put slicks on the back and went up to the strip........ If you plan on doing that with a built 351w like mine you need either a tremec or world class t-5....... or an old 4 speed toploader to handle it ![]() good luck!!! |
Threads Similar to: Stock 302 H.O Head questions
| Help w/ stock head unit | eprench | Audio/Video | 1 | September 16th, 2007 10:35 AM |
| Stock head and Intake Porting | GizmosMustang | 5.0 Mustangs | 21 | May 3rd, 2007 10:29 PM |
| Looking for new stock head lights | Onemanzu | V6 Mustangs | 30 | March 30th, 2007 01:55 AM |
| Stock 94 Head Combustion Chambers | 94GTD1SC | 94-95 | 0 | March 24th, 2007 11:12 PM |
| Head Porting Questions! | 96greenGT | 99-04 | 13 | November 14th, 2006 09:21 PM |
