t-5 swap
Old October 24th, 2007, 01:48 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
t-5 swap
ok i put the clutch and brake pedal assembly in my car and im picking up the t-5 tranny tonite but my question is what else do i need beside the clutch,cable and flywheel, like the little odds and ends.
85 svo. work in progress
Old October 24th, 2007, 02:37 PM   #2
ryans88gt's Avatar
Bellhousing?? Clutch fork, and ball stud, the little clip that holds the clutch cable on the bellhousing, inspection cover that covers the cable and fork, shifter, new center console trim, leather shifter boot, 3 quarts of ATF, a new trans mount, the four bolts that hold the trans to the bellhousing...pilot bearing, throwout bearing, alignment tool (should come with the clutch). I'd replace the rear main seal while you are back there (it'd suck to have to tear it apart again 10 mile later). I'm sure there is other stuff too, neutral safety switch (clutch starter switch).
Old October 24th, 2007, 02:55 PM   #3
novamastr's Avatar
novamastr is on a distinguished road
If the car was an Auto you wont need to hook up the neutral safety switch.Mine started without it.
91 LX coupe,Aluminum heads,Steeda roller rockers,Typhoon Intake,F303 cam,Cold Air Intake,Tremec T5, Cobra R Rims, MSD ignition, MSD distributor, FMS Cobra LSD w/3:73 Gears and 31 spline axles.
Old October 24th, 2007, 06:00 PM   #4
ryans88gt's Avatar
Sure if you don't mind not having an important safety feature...
Old October 25th, 2007, 06:54 PM   #5
ok i got the tranny and the guy gave me the bell housing with it. i ordered a shifter, i can get a clutch at my work(pep boys) comes with pilot & throwout bearing also an alignment tool. im gonna look on ebay and craigslist for the flywheel (157 tooth, 50oz ?) and clutch fork. where can i get the bolts that connect the bell housing to the tranny and the pressure plate to the flywheel? also what are the 2 electrical connecters on the left side of the tranny?
Old October 25th, 2007, 08:54 PM   #6
Speedstang302's Avatar
13.64@101mph
yes 50oz flywheel..if have money get an aluminum lightweight one..billet ones are even nicer but more $$$...
i wouldnt get a pep boys clutch...get a king cobra, or spec, or zoom, or centerforce!!!!
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 25th, 2007, 09:11 PM   #7
1987 ford mustang gt
well see when shes done
i only paid like 160 for my probe billet flywheel
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 25th, 2007, 09:51 PM   #8
13.64@101mph
ford racing billet flywheels are like low 300s...mine was an lightweight aluminum for like 189
Old October 28th, 2007, 08:49 PM   #9
i got this flywheel. http://cgi.ebay.com/ebaymotors/ws/eB...164481657&rd=1
also what is a ball stud and do i need that plate thing that goes between the bellhousing and the engine
Threads Similar to: t-5 swap
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
3.8 swap to 5.0 goldhorse V6 Mustangs 1 August 10th, 2007 12:57 AM
351 Swap Cskit1500 5.0 Mustangs 6 November 16th, 2006 07:40 PM
