What are the Stock gear ratios are in a T-5 in an 88 Mustang
Old October 24th, 2007, 09:12 PM   #1
NYHigH's Avatar
NYHigH is on a distinguished road
Anyone know the stock gear ratios for a T-5 in an 88 mustang gt?
Are 87-93 all the same ratios? (tranny wise)
Old October 24th, 2007, 10:30 PM   #2
NYHigH's Avatar
bump
Old October 24th, 2007, 11:05 PM   #3
1987 ford mustang gt
well see when shes done
no they are not all the same
this is from 86.5-89 mustangs 3.35 1.93 1.29 1.00 0.68
347, torn apart again.
Old October 24th, 2007, 11:26 PM   #4
NYHigH's Avatar
Ok, thanks alot. The reason I was asking was because I was comparing what the RPM would be on an 88 Mustang GT with a T-5 and T-56:
At: 85mph with stock 2.73 rearend in 5th gear with T-5
And: 85mph with 4.10 rearend in 6th gear with T-56
It seems like the RPMs are about the same.
I found this helpful website to calculate all of this if anyone is interested. The website says it's not 100% accurate, but it seems pretty damn close to me. Well here it is if no one has established this yet:
Note*: I'm not sure if this site pertains to a certain vehicle, but i don't think it matters because i tried the calculations on some other website.
http://tech.oldsgmail.com/axle_RPM.html
I'll post it on a new topic also.
Old October 24th, 2007, 11:30 PM   #5
this is darrells sight http://webpages.charter.net/darrell1/calculators.html
Old October 24th, 2007, 11:37 PM   #6
NYHigH's Avatar
Oh, ok.......thats good to know.
Well anyway, that's gotta be pretty sick with the T-56 running a steep ass gear and still being able to cruize like normal when you want.
Old October 24th, 2007, 11:40 PM   #7
NYHigH's Avatar
Ok, i've just noticed something. I'm not trying to step on toes here but on Darrel's website, it doesn't give the option of entering Tranny ratios.........does it?
Old October 24th, 2007, 11:40 PM   #8
they are very nice transmissions but they are just so pricey
Old October 24th, 2007, 11:46 PM   #9
cali 5.0 is on a distinguished road
i jus went to the 1st web site (not darrels) and it says tht at 90mph in 4th gear i should be at 4392 rpm and in my car it says 5000. i've got 3.73 gears stock tranny 5spd and i put 2 different speedo gears in and they both gave the same reading. anybody no whats wrong with my car
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old October 25th, 2007, 12:10 AM   #10
Ok, I just thought of something after seeing the difference in the 1st gear ratios between:
T5: 1st gear @ 3.35 ratio with stock 2.73's at 25mph= about 3000RPMs
1st gear @ 3.35 ratio with 4.10's at 25mph = about 4500RPMs
T56: 1st gear @ 2.66 ratio with 4.10's at 25mph = about 3500 RPMs
Doesn't seem like your gaining much. What's the point of spending 3gs on a T56? The whole point is the low first gear but it seems the 2.66 gear on the T56 brings it right back to stock WTF?
i would spend my money somewhere else and if a new transmission is needed i would buy a tko600 it will handle more than the t-56 but it only has 5 gears but who needs a 6th gear but if you had 4.10's you could run much faster on topend if thats what your into
Old October 25th, 2007, 12:11 AM   #11
the stock guages are not accurate especially the tachs
Old October 25th, 2007, 12:17 AM   #12
i got an aftermarket tach also and they both read about the same
Threads Similar to: What are the Stock gear ratios are in a T-5 in an 88 Mustang
3.73 4.10 gear ratios SilverGT04 99-04 2 November 30th, 2010 07:39 PM
gear ratios in an 07 stang innrkid 2005 - 2010 15 May 22nd, 2007 01:38 AM
Gear Ratios dStoltenberg 5.0 Mustangs 15 April 19th, 2007 09:36 PM
Anyone know stock production numbers and gear ratios? YNOT 5.0 Mustangs 7 March 17th, 2007 09:16 PM
Gear Ratios 00RoushV6 V6 Mustangs 16 February 20th, 2007 10:32 PM
