1985 Mustang GT
14.72 @ 93.84
Exactly What Makes A "306"
I just got my a mustang yesterday and the guy said it has a "306" i know obviously the GT's came with a 302, but why would you bore it out to just a 306? im guessing, (im coming here for a better answer) that the engine was rebuilt and bored (how much) for some reason? pls help, i just want to know why.
1987 Mustang GT
Exactly what makes a "306"
a 306 is a 302 thats been bored .30 over
soon to be fox body
more power and better performance with the right setup
starting from scratch |
1985 Mustang GT
14.72 @ 93.84
mmm.... more power
explain this good setup pls ![]() as far as i know the motor itself is stock: don't you just hate it when the person you buy the car from doesn't know much about whats been done to it
1983 GT
UNKNOWN
more than likely it was just rebuilt and when you rebuild a motor typically its bored over. its just like re assuring the rings will seal correctly because there could be tiny scratches or somethin if it isnt rebored
1983 FOX BODY-LIL SOMTHIN IN PROGRESS |
boring an engine doesnt make a whole lot of extra cubic inches.....with a big block you would see a lot bigger difference with the same amount of bore because it gona be a type of exponential increase.....but even then its not a huge gain in cubes
13.64@101mph
boring to a 306 makes no real power. its about 1.5hp per cubic in. making it have 6hp more than it had as a 306..so for $500 not worth it...now its is worth it when you add supporting mods and is an almost must have of stroking an engine..when rebuilding it is usual that is isnt bored out..just rebuilt, the boring will make block fresher..so unless you are doing more work to it, you're going to be slower than a 302 w/ underdrive pullys!!!
also ask previous owner for paper work on this..cuz ALOT of people say stuffs be done that cant be seen by the eye immediatly and its NEVER been done!!!
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
102 x 3 =
Big timin' in a small town
Not even worth it to change your motor to a 306. Why might you ask because your going to have to buy new pistons anyway. You should just go straight for a stroker like a 331 or 347 because you will already have the engine completley apart and you should just go the rest of the way to make it have just that much more power
#10 | |
13.64@101mph
#11 | |
13.64@101mph
The only time boring an engine should be done is when the cylinders are worn.
#13 | |
13.64@101mph
#14 | |
#15 | |
#16 | ||
13.64@101mph
#17 | |
but alot of people don't have a fresh block to start with because they dont have the know how or the money.but why would you bore it to .30 jus to make it a 306.
GO FAST.... or be a tuner |
#19 | |
But yeah, boring an engine to add a few cubic inches is a waste.
#20 | ||
13.64@101mph
Threads Similar to: Exactly What Makes A "306"
| This just makes me cry. | ArmyStang07 | 2005 - 2010 | 17 | November 3rd, 2007 12:10 AM |
| Who makes this thing | bluethunderhorse | 5.0 Mustangs | 7 | August 25th, 2007 03:30 PM |
| grr makes me angry | mustang kid 1989 | The Clubhouse | 10 | July 7th, 2007 12:44 AM |
| who makes the best headers | baine21225 | 5.0 Mustangs | 11 | June 21st, 2007 12:22 AM |
| this makes me sad | joejoe8455 | The Clubhouse | 59 | June 14th, 2007 11:02 PM |
