#21 |
that QA1 kit is great, is alot lighter and gives you more header and oil pan clearance.... Good stuff, double ckeck application on 86 & older stangs.
www.hsvracing.com |
#22 | |
#23 |
El Conquistador
just a update i bought a aje front kit with k member,a arms,coilover kit, not sure of delivery time but should be in next week or so
#24 |
what are you doing for struts?
#25 |
oh and you might want to order some caster camber plates from D&D so you wont have to modify the stock onion bushings when you do the coilovers
#26 |
El Conquistador
the plates came with the kit and i was thinking lakewood
the owner was trying to steer me away from the lakewood traction action bars i have now and just go with a upr lower and upper along with a anti-roll bar kit from upr but again this will also be a street drivin car for cruises and every now and then into town |
#27 |
El Conquistador
holy old thread that yes i am digging up!!!!!
yes i know its sad, but yes i just now got around to having the k-member put on along with pulling the motor and replacing gaskets and the timing chain and painting her up and rewiring under the hood, also scored a aluminum radiator and 2.5" cowl hood new suspension consist of... aje k-member lakewood 70/30 struts lakewood traction bars lakewood rear uppers |
Threads Similar to: front suspension
| 65 Front Suspension? | Spiderz | Classic Mustangs | 11 | July 24th, 2007 04:39 PM |
| Noisy front suspension | stanglover99 | General Tech | 1 | July 18th, 2007 03:56 AM |
| Front End Suspension Install... HELP. | 88BlueGT | 5.0 Mustangs | 7 | February 28th, 2007 08:42 PM |
| Cobra front? ROUSH Front? or Mach1 Chin? | Chris02 | 99-04 | 11 | November 19th, 2006 12:10 AM |
| FR500 front suspension | banini | Modular Mustangs | 0 | September 25th, 2006 02:39 PM |
