Raising the Compression Ratio in a 347 Stroker SBF
Old August 13th, 2006, 02:45 PM   #1
Zak
Zak is on a distinguished road
Anyone has an idea if it's OK to raise the compression ratio from 10:1 to 10.5:1 in a naturally aspirated 347 cid small block that has an aluminum head, 30# injectors and sees only premium gas (even 98 octane most of the times)?
I also don't know how much should I set my initial ignition timing. I'll be using MSD ignition controller & HVC coil.
I wanna mill the deck .005" and the World Windsor Sr .005" (this should reduce the combustion chamber volume by 1 cc approx) and to use a thinner head gasket. I'll use a Fel-Pro of .038" compressed thickness instead of my current Cometic .045"
Old August 13th, 2006, 05:38 PM   #2
1985 GT
none yet
chvyeter is on a distinguished road
You'll have no problems unless you start getting around 12.1
Old August 13th, 2006, 10:10 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
10:5:1 should be ok with 93 octane. Anything more will detonate and you might not here it but it will surely show up on a dyno graph.
Old August 14th, 2006, 10:00 AM   #4
Zak
Thanks for your info, guys..
After some thinking, I'll stick to my original 10:1 plan cuz if I wanna go to 10.5:1 I'll need to do a lot of machine work on the block deck, cylinder heads and intake manifolds.. perhaps need to notch pistons too.
Threads Similar to: Raising the Compression Ratio in a 347 Stroker SBF
Compression Ratio itschristorres8 V6 Mustangs 22 December 1st, 2007 02:46 PM
Compression Ratio scxc15 Modular Mustangs 4 September 25th, 2007 12:01 AM
compression ratio mustangrebuilder Classic Mustangs 13 August 14th, 2007 11:08 PM
compression ratio for 93' 5.0 V8 w/ modifications kelbry 5.0 Mustangs 4 May 10th, 2007 11:37 PM
96 gt compression ratio 96_gt_stanger 96-98 3 March 3rd, 2007 12:52 AM
