1987 Mustang GT
Trick flow head question????
ok i got a set of trick flow heads im going to be putting on this weekend and i was just wondering about the pollution tubes that attach to the back of the factory heads ( not sure what you call them). I have taken all the other pollution stuff off of the car and i would like to get rid of the tubes too but what do i do about the holes on the trick flow heads do i just put a pipe plug in there??
1987 ford mustang gt
well see when shes done
yes that would work just get somethin to block the holes off with
1987 Mustang GT
cool thanks jordan i thought that would work but i wasn't sure . cant wait to get those on and put the new cam in it
that hole's not threaded jordan...
www.hsvracing.com |
i know they are not threaded!!!what are you implying???
1987 Mustang GT
they look like they are on the trick flows
#7 | |
yea if it's threaded plug it. jordan u so funny!
www.hsvracing.com |
1987 Mustang GT
I missed something didnt I ????? LOL !!!
The smog holes in the Trick Flow heads are threaded and Trick Flow sells plugs for them for a couple bucks each.
1987 Mustang GT
is there anything special about the ones trick flow sells or are they just pipe plugs?
I just went to the local hardware store and picked up a couple.dont remember the size though.you might find the size through summit.I put loctite on them before install.
#12 | |
Re: Trick flow head question????
Threads Similar to: Trick flow head question????
| Top End Kit AFM or Trick Flow | rvdooley | 5.0 Mustangs | 5 | November 12th, 2007 07:22 PM |
| Trick Flow Top end kit. | Timm10221 | 5.0 Mustangs | 23 | October 17th, 2007 03:36 PM |
| trick flow | Iownastang | 5.0 Mustangs | 7 | July 6th, 2007 01:50 AM |
| gt 40 or trick flow? | 95wip | 94-95 | 8 | April 21st, 2007 11:42 PM |
| trick flow top end kit on a dss 331 | stangzilla 331 | 94-95 | 10 | March 30th, 2007 08:45 AM |
