Build up or buy crate engine?? Where to go for crate engine
Old October 27th, 2007, 11:33 AM   #1
cgb6810 is on a distinguished road
I've got a automatic 94 gt vert (65,000 miles) that Im looking to add some power too. Ive already added; flowmaster cat back exhaust, BBK cool air intake, transgo shift kit, 3:73 gears and lowered 1-1/2" with tokico shock/spring kit. Just these things have really transformed the car.
Id like to see approximately 350 hp or so. This is just a street car driven maybe 3000 miles per year. I was originally thinking about installing the Trick Flow top end kit with headers. I have to pay a mechanic to install, so I would be in the $3000+ range for the trick flow option.
Other options I might consider are; turbo or supercharging, motor swap or maybe build to 347?
Any opinions would be appreciated. I might spend more then $3000 of it made more sense in the long term.
Old October 27th, 2007, 12:03 PM   #2
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
2012 Hyundai Elantra GLS
Vinyl66 has a spectacular aura aboutVinyl66 has a spectacular aura aboutVinyl66 has a spectacular aura about
Send a message via AIM to Vinyl66
crate engines
http://www.proformanceunlimited.com/ford.html
Pittsburgh Steelers/Penguins/Pirates FTMFW!!!!!
Old October 27th, 2007, 12:42 PM   #3
TENGRAM is on a distinguished road
http://fordstrokers.com/
89 GT t5 3.73
www.my5oh.com/
Old October 27th, 2007, 12:54 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old October 27th, 2007, 01:04 PM   #5
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
i like that site im thinking about stroking mine into a 347 once i get more cash put together.
Old October 27th, 2007, 01:15 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Woody owns Ford Strokers. He is a member on this site.
Old October 27th, 2007, 01:16 PM   #7
1987 ford mustang gt
well see when shes done
And sells coast high stroker kits
347, torn apart again.
Old October 27th, 2007, 01:18 PM   #8
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
badass i didn't know that
Old October 27th, 2007, 02:10 PM   #9
The Razor's Edge
White Thunder's Avatar
id say either stroke your motor you already have or buy a short block and build it your self. ford strokers gives you some good options but as far as cams and intakes your on your own. look for a custom grind i know there is links on here somewhere...jay Allen at camshaftinnovations.com.
founder of the FTN Club
Old October 27th, 2007, 02:27 PM   #10
1989 GT
Lauri is on a distinguished road
For goal of 350 horses i'd go with Trick Flow h/c/i set. It may not give you all that, but still would be my choice.
Old October 27th, 2007, 02:33 PM   #11
the trick flow kit and a 347 will giv you around 400 fwhp
Old October 27th, 2007, 02:56 PM   #12
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
ive seen AFR advertise putting their heads on a stock 302 to make close to 400hp. i don't know how much i believe that but with some simple mods and those heads you should be at 350
Old October 27th, 2007, 03:04 PM   #13
not exactly thats on a motor dyno and its oriobably a really high revving engine
Old October 27th, 2007, 03:09 PM   #14
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
if i wanted to stroke my 302 would i have to change my heads (289 hi-po) because they will starve the engine?
Old October 27th, 2007, 03:23 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It wasn't a stock 302. The engine was a stock short block with a stock 5 liter hydraulic roller but it also had 1.7 ratio rockers, a Weiand Stealth intake, Demon carb and stepped headers. They also used a Superflow dyno which is a bit optimistic. With a DTS dyno that engine wouldn't have fallen short of their mark.
Old October 27th, 2007, 04:20 PM   #16
good suggestions
Thanks for the suggestions and links guys. Ford strokers looks good.
More to think about......
Old October 27th, 2007, 05:23 PM   #17
1965 Mustang Fastback
nba1341 will become famous soon enough
crate engines
over-priced crate engines
and boy do i mean over-priced!!! even with the warranty
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old October 27th, 2007, 11:33 PM   #18
13.64@101mph
+1 on coast high and ford strokers.
and as far as custom cam i say ed curtis at flowtech...
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Threads Similar to: Build up or buy crate engine?? Where to go for crate engine
Crate engine Wally1968 2005 - 2010 9 September 11th, 2007 05:11 PM
Crate Engine jkonfuzhon 94-95 13 March 2nd, 2007 05:46 PM
Crate engine dblindberg 2005 - 2010 5 January 19th, 2007 06:41 PM
New Crate Engine In A Classic 69? extropy Classic Mustangs 9 September 28th, 2006 07:01 AM
Crate Engine Or Not? black94gt 5.0 Mustangs 11 September 8th, 2006 12:01 AM
