Towing a mustang - Forums at Modded Mustangs
post #1 of 20 Old October 28th, 2007, 02:18 AM Thread Starter
fastford3388's Avatar
Send a message via AIM to fastford3388
Towing a mustang
So I had my car towed on a tow dolly for about 45 miles and they went on the high way. they put the rear wheels on the ground and put the tranny in neutral and never removed the drive shaft. Is there a possibility that my AOD is trash? Could changing the fluid and the filter before i drive on it help? is there a way i can tell?
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
fastford3388 is offline
post #2 of 20 Old October 28th, 2007, 02:21 AM
FoxHoss's Avatar
Send a message via AIM to FoxHoss
ive heard that rule of thumb is to not go more than 50 miles... i would change the fluid tho. the only way your really gonna be able to tell without hookin up pressure gauges and what not is to just drive it
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
FoxHoss is offline
post #3 of 20 Old October 28th, 2007, 02:28 AM Thread Starter
well if i drop my pan and i find TONS of metal shavings i'm probably screwed. but how do i really know? How much shavings is too much?
post #4 of 20 Old October 28th, 2007, 02:29 AM
UUUUUUUUUUUUUHHHHHHHHHHH THERE SHOULDNT BE ANY METAL SHAVINGS
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Iownastang is offline
post #5 of 20 Old October 28th, 2007, 02:36 AM
TurboLX's Avatar
:homo
TurboLX is offline
post #6 of 20 Old October 28th, 2007, 07:36 AM
1slo5.0's Avatar
Re: Towing a mustang
There is no reason to remove the driveshaft. What would the difference be if you were driving it or having it towed? If they would have removed the driveshaft, transmission fluie would have poured out of the tailshaft. There are people that tow their vehicles 2000+ miles daily behind their motorhomes. Whoever told you that you need to remove the driveshaft is wrong.
1slo5.0 is offline
post #7 of 20 Old October 28th, 2007, 08:34 AM
The Razor's Edge
White Thunder's Avatar
but you just put 50 miles on your car.....duude thats kinda funny
founder of the FTN Club
White Thunder is offline
post #8 of 20 Old October 28th, 2007, 04:57 PM
FoxHoss's Avatar
im sure your AOD is fine. the problem with towing long distances (ie rule of thumb 50 miles) is that the internal parts of the AOD need lubrication when they are being rotated. when you are in tow, you are actually spinning the internals of the transmission which will start to cause rapid wear due to the lack of lubrication. there is no lubrication because the pump is located in the front of the transmission and is driven by the torque converter which is in turn driven by the flex-plate which is driven by the crank... thus, no engine rotation, no fluid being pumped through your transmission... in short that is why towing your vehicle without removing the driveshaft is very threatining to the life of your transmission. very similar to running your engine without an oil pump....
FoxHoss is offline
post #9 of 20 Old October 28th, 2007, 04:59 PM
why not just use a flatbed?
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
nba1341 is offline
post #10 of 20 Old October 29th, 2007, 01:24 AM Thread Starter
Thanks guys! I'm gonna change the fluid and the filter for good measure anyway though. It was towed already and i really had no choice in the matter, otherwise i would have gotten a flatbed
post #11 of 20 Old October 29th, 2007, 09:39 AM
Resident Bubblehead
00vabchgt's Avatar
+1. anytime i have my car towed, i tell them to send a flatbed and nothing else...
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
00vabchgt is offline
post #12 of 20 Old October 31st, 2007, 12:34 PM
86GT50's Avatar
Your tow shouldnt of hurt anything..... your trans was probably hurt before the tow.... why didnt you just drive the car the 50 miles???
86GT50 is offline
post #13 of 20 Old November 5th, 2007, 01:46 AM Thread Starter
Ok so I checked the transmission today and i found barely any trans fluid on the dipstick and the car will not go into gear. found there is a leak in the tail shaft seal and it probably leaked out all the fluid through that rear seal. has anyone ever had that happen to them? I plan on replacing the seal and the u joints on the drive shaft while i'm at it. is there anything else i should really look for or replace while i'm replacing the rear extension housing seal? also what is the difference between the booted and un-booted seal?
thanks guys!
post #14 of 20 Old November 6th, 2007, 12:19 AM Thread Starter
bump
post #15 of 20 Old November 6th, 2007, 12:38 AM
mastrb8n & modr8n
BWAL's Avatar
yes, if you find metal shavings you will be screwed.
oh wait, i thought you said if you dropped your PANTS
j/k
and yeah, use a flatbed next time
'65 Fastback
'89 LX 5.0
'90 LX 5.0
'92 LX 5.0
'92 LX 5.0
'97 Cobra
instagram
Originally Posted by RDY4WAR View Post
god is a little bit gay
BWAL is offline
post #16 of 20 Old November 6th, 2007, 01:17 AM
quit screwin around and dump the coin for a built aod, if you ran out of fluid youre screwed,trust me i went through 4 stock aods
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA
3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH
lugnutz08 is offline
post #17 of 20 Old November 6th, 2007, 01:29 AM Thread Starter
Yeah the only thing keeping me from doing that is money, i'm a broke @$$ college student who eats ramen for dinner most nights. haha! ill get my degree and fix this bad boy up! performance everything after that!
anyone know the difference in the seals though? seriously?
post #18 of 20 Old November 6th, 2007, 01:50 AM
get a racing c4 for 1000 dollars?
then add an overdrive gear to it? then another?
I'm a good boy now.
nba1341 is offline
post #19 of 20 Old November 6th, 2007, 01:53 AM
The Boss is in
8t6gt's Avatar
GTFO NBA
jk you can stay I guess
8t6gt is offline
post #20 of 20 Old November 6th, 2007, 01:37 PM
FoxHoss's Avatar
i beleive one of the seals just has some excess rubber around it so that any fluid that seeps by dosent get flung all over your undercarage... thats how it was for my manual trans tho
FoxHoss is offline
Human Verification
