bolts
i need bolts that attach the bell housing to the t-5 tranny and the bolts that attach the pressure plate to the flywheel, where can i get them?
85 svo. work in progress
13.64@101mph
hardware store, autozone..you just gotta know the size..i think bellhousing bolts are 5/8..not 100% sure though
#3 | |
i found these for the pressure plate bolts http://mustangsunlimited.reachlocal....reachlocal.net
can i use the auto flywheel bolts to attach the manual flywheel
#6 | ||
13.64@101mph
duct tape it up there, it'l be ok
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1987 Mustang GT
bolts
if you cant duct it f..k it!!!!
my thoughts exactly
1987 Mustang GT
bolts
Lol !!!!!
Yeah, you need the correct bolts for the trans to bellhousing. I'm not sure if they have the normal thread pitch since they are screwing into aluminum.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#12 | |
Threads Similar to: bolts
| oil pan bolts | stainless1 | 2.3 Mustangs | 3 | July 12th, 2007 10:40 AM |
| oil pan bolts | stainless1 | Modular Mustangs | 4 | July 11th, 2007 05:11 PM |
| oil pan bolts | stainless1 | V6 Mustangs | 3 | July 10th, 2007 08:17 PM |
| what size bolts | jersey98gt | 96-98 | 9 | May 14th, 2007 11:10 PM |
| studs or bolts | mustangman36578 | 96-98 | 1 | March 28th, 2007 11:25 PM |
