Problem w/ Starting Car
Old October 28th, 2007, 08:33 PM   #1
Speedstang302's Avatar
13.64@101mph
Ok..yeah i should know.this but kinda stumped...it wont start, i just got the new BBK 255lph fuel pump in today, wired and all sensors in and tank back into place...and well car hasnt run in a while, cuz took apart to but on the harland sharp 1.6 rr's, chromemoly pushrods, double valve springs etc..well i replaced old accel cap and rotor w/ msd cap and rotor, and idk i think i screwed up timing..and cant get it running to use timing light..it just cranks, makes not effort to start, and i dont hear fuel pump priming when i turn key on..and all plug wires are in right spots..but if its not getting fuel it will not start..so even if timing was off it should start hard or just crank harder, but cranks smoothly..can also still do not have vaccum ports correct...but all are either right stuff attached or plugged..help..thanks
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 28th, 2007, 08:55 PM   #2
TENGRAM is on a distinguished road
have you checked the fuel pump inertia switch under the panel in the back of the car? might need to drop the tank again and verify that everything is plugged in.
89 GT t5 3.73
www.my5oh.com/
Old October 28th, 2007, 09:02 PM   #3
13.64@101mph
i checked it all before rebolted it back up, cuz tried starting it w/ tank loose but everything connected...and everthing is tight, and no plugs undone..and what fuel pump switch in the back?
Old October 28th, 2007, 09:03 PM   #4
13.64@101mph
i checked it all before rebolted it back up, cuz tried starting it w/ tank loose but everything connected...and everthing is tight, and no plugs undone..and wheres the fuel pump switch in the back?
Old October 28th, 2007, 09:22 PM   #5
its in the hatch behind the rearmost plastic panel...toward the driver side. just press the button on it.
89 GT t5 3.73
www.my5oh.com/
Old October 28th, 2007, 09:31 PM   #6
13.64@101mph
and this button will do what...solve world hunger?
jp...but seriously?
Old October 28th, 2007, 10:40 PM   #7
jp...but seriously?
the inertia switch is supposed to get tripped when you are in a rollover collision, i n which case it shuts off power to the fuel pump. sometimes it gets tripped by something minor (ie going up a steep hill, accidently bumping the switch, etc). hitting the button resets the switch, restoring power to the fuel pump. really its a longshot but it wouldn't be the first time i've seen that problem. otherwise you need to test some wires going to the relay...
89 GT t5 3.73
www.my5oh.com/
Old October 28th, 2007, 10:45 PM   #8
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
check the fuel pump relay off the computer as well. you can get a schematic from autozone.com
Old October 28th, 2007, 10:48 PM   #9
13.64@101mph
jp...but seriously?
OK..yeah i know its a kinda killswtich thing...i may have hit it cuz im redoing interior, put battery in back and building custom rear seat delete..also i removed GT rear bumper and side brackets so i could have easily hit it not knowing..i'll do that tomorrow..how will i know the switch thing is working..also if its not the fuel problem..what else could it be..why it wont start..
Old October 28th, 2007, 10:50 PM   #10
13.64@101mph
schematic..like a computer tester kinda thing...how much we talking..goddamn i sound like a noob..but i dont fully get this computer and efi shit..
Old October 28th, 2007, 10:54 PM   #11
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
check the relay under the drivers seat first. The schematic its free at autozone.com. A schematic is jus a wiring diagram.
Old October 28th, 2007, 10:57 PM   #12
if hitting the switch works, the next itme you turn the key to "on" you'll here the fuel pump prime. if thats not it you'll need to check some other things like the fuel pump relay, ignition switch etc. let me know. the non-code related electrical stuff is not my favorite but i'll help you as best as i can.
autozone.com...its free. just go under "repair info" and you should find it.
89 GT t5 3.73
www.my5oh.com/
Old October 28th, 2007, 11:08 PM   #13
13.64@101mph
thanks
and
gotcha..
Old October 28th, 2007, 11:14 PM   #14
13.64@101mph
also could it be the fact that i basically have no gas...yeah that sounds blonde...but i now remember seeing very little gas in tank, fuel pump didnt even touch gas when i has it fully in..i thought i filled it, but dad said he has had gas tank all week..so i couldnt have..
Old October 29th, 2007, 12:31 AM   #15
you would still be able to hear the fuel pump prime.
89 GT t5 3.73
www.my5oh.com/
Old October 29th, 2007, 12:47 AM   #16
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
i had that prob when i changed throttle bodys, the tps was way off.
Old October 29th, 2007, 01:42 AM   #17
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
either way it sounds like a fuel pump problem because you should be able to hear the pump kick on with the key on engine off....
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old October 29th, 2007, 09:30 AM   #18
13.64@101mph
i know..but if theres no fuel for the pump to pump..than see what im saying..
Old October 29th, 2007, 09:31 AM   #19
13.64@101mph
i know..when i get outa school ima going to check into the inertia switch..
Old October 29th, 2007, 09:32 AM   #20
13.64@101mph
Re: Problem w/ Starting Car
i have recently sold all my motor stuff..and went back to stock (to get money in the bank) but i went back to stock TB..so that shouldnt be fucked up..
Threads Similar to: Problem w/ Starting Car
problem starting Fastpitchdad General Tech 12 May 23rd, 2007 08:00 AM
Problem starting up sbx213 5.0 Mustangs 5 March 11th, 2007 11:46 PM
problem starting mustangman0001 5.0 Mustangs 3 March 4th, 2007 01:52 PM
Starting Problem 97_4.6L_Stang Modular Mustangs 5 January 23rd, 2007 10:01 PM
Car Starting Problem In My 03 GT autostang03gt 99-04 3 November 13th, 2006 01:09 AM
