1992 LX 5.0
stock fuel pressure
Anyone know what the stock fuel regulator is set at?
On the dyno the other day the car was running rich, i would like to try an adj. fpr before going back. All the adjustable regulators seem to range from around 30-35 to 65-75. Didn't want to put one on yet if the stock one is 30, I wouldn't be able to lean it out for any gains. |
1987 Mustang GT
stock fuel pressure
i wanna say the stock fuel pressure is 39 psi
yeah like 39 Plus or minus 10 ...
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1992 LX 5.0
thanks
lowering the fuel pressure isn't likely to lean you out any (temporarily it will but not long term). the ECM determines the A/F ratio based on o2 sensor readings, so changes to fuel pressure are negated by the ECM by lengthening/shortening injector pulsewidth.
if you are running rich there is another problem; ie miscalibrated mass air meter, faulty o2 sensors or wiring, exhaust leak causing the o2s to read lean, bad tune via chip or piggyback tuner, etc etc. Check the Codes to find out why you are running lean rather than jacking with the fuel pressure and possibly screwing up your injector spray pattern and atomization. my2cents |
Threads Similar to: stock fuel pressure
| Fuel Pressure Regulator Leaking Fuel | Buttaz | V6 Mustangs | 4 | August 17th, 2007 11:41 AM |
| No fuel pressure, Fuel gauge went above full and stayed. | woodz72 | 96-98 | 6 | July 10th, 2007 06:58 PM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
| 05+ GT stock fuel pressure | Stangorama | 2005 - 2010 | 4 | March 15th, 2007 11:51 AM |
| 5.0 HO fuel pressure stock | 1st fox body | 5.0 Mustangs | 4 | January 19th, 2007 03:50 PM |
