Stock timing chain question?
Old October 29th, 2007, 11:12 AM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
Well i took the stock heads off and removed the cam this weekend and i noticed that the timing chain was a double roller that was on there. Now was that factory on 5.0's ? The cylinders looked really good too no ridge and i can still see the cross hatch hone pattern in there. Just wondering if someone rebuilt the motor before i bought the car or if it was just really well cared for.
Old October 29th, 2007, 12:13 PM   #2
Racinjason81 is on a distinguished road
ford uses a single row chain someone probably upgraded to a double row chain
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old October 29th, 2007, 01:04 PM   #3
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
well i thought the same thing when i took my 89' apart but when i whent to the advance auto and got a stock replacment it was a double roller as well... i dunno if its just a "revised replacment" or what
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old October 29th, 2007, 04:51 PM   #4
Speedstang302's Avatar
13.64@101mph
no the roller 5.0's have double roller chains...also what heads and cam are you putting in?
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 29th, 2007, 11:47 PM   #5
jam77's Avatar
1987 Mustang GT
I have a set of trick flow heads and a anderson b-31 camshaft going on
Old October 30th, 2007, 12:12 AM   #6
jam77's Avatar
1987 Mustang GT
that cam is suppose to work really well wit the blower and im going to get a smaller pulley on the s/c . Trying to get over 400 horse to the rear tires.
Old October 30th, 2007, 09:42 AM   #7
13.64@101mph
Re: Stock timing chain question?
...jp...sounds awesome...post a video and pics when done...
Old October 30th, 2007, 09:42 AM   #8
13.64@101mph
you should be when all's said and done
Old October 30th, 2007, 11:04 AM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
5 liter H.O. engines have a double roller timing chain from the factory.
Threads Similar to: Stock timing chain question?
timing chain gear instalation FoxHoss 5.0 Mustangs 4 October 21st, 2007 12:05 AM
timing chain gear instalation height?? FoxHoss 99-04 0 October 20th, 2007 11:54 PM
TIMING CHAIN REPLACEMENT CRZCOBRA Modular Mustangs 1 July 9th, 2007 05:49 PM
4.6 V8 4v timing chain set-up Mauriello Motorsport 4V / SVT 2 May 25th, 2007 11:10 PM
broken timing chain guide blown_97cobra 96-98 18 February 26th, 2006 09:57 PM
