5 lug conversion
Got a 93 GT. Looking to convert the 4 lugs to 5 lugs and possibly disc brakes out back. Haven't had drum brakes for a while and want to be able to stop decently. What's the cost effective swap($$) and what tips do you guys have to make it a simple process?
RLY SRS
You could prolly find a wrecked SN95+ mustang with disc rear-end and take the whole rear end, brake booster, and master cylinder...Then you would have a good start on the swap and prolly would be alot cheaper...
11.47@120.58
For the front all you need is Mark VII rotors. The rear would be a pair of 5 lug axles from a Ranger or Aerostart (I forget which side, but you need the both from one of them). Those would be drum though. There are some Mustang parts houses that sell Cobra kits for the rear disc... pretty expensive though. I'm not sure, but I don't think you can use the SN95 rear end because it's wider. Maybe you could use it will different backspacing rims, I dunno.
#4 | |
RLY SRS
Some Info |
1999 Ford Mustang V6
the axle tubes on the foxs are slightly shorter than the sn-95 8.8's
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Front:
79-86 and 87-93 4cyl Mustangs - use 4cyl 83-92 Ranger rotors 87-93 V8 Mustangs - use 85-91 Lincoln Mark VII rotors Rear: 79-93 Mustangs - use '83-'92 4 cylinder/3.0 V6 Ranger/Bronco II left (driver) side axle and drums or '86-'97 Aerostar right (passenger) side axles and drums
its the left side from a ranger that you need
Threads Similar to: 5 lug conversion
| 2v to 3v conversion??? | droppedbass87 | 96-98 | 26 | September 18th, 2010 01:08 AM |
| conversion | Mustang RacR94 | 99-04 | 8 | April 2nd, 2007 11:02 PM |
| 2.3L to 5.0L conversion | stan_doe | 5.0 Mustangs | 6 | January 23rd, 2007 01:39 AM |
| 99-04 V6 To GT Conversion ?'s | ineedajob | V6 Mustangs | 7 | November 9th, 2006 04:18 PM |
| After A 5 Lug Conversion... | 347tt | 5.0 Mustangs | 7 | September 28th, 2006 03:53 PM |
