TPS
Old October 30th, 2007, 09:03 AM   #1
1989 Mustang LX
89StAngerLX is on a distinguished road
TPS
What can cause low voltage to the tps?
Jesse
Old October 30th, 2007, 09:05 AM   #2
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
Not for sure of what may cause it, but in order to increase it you will need to bore out the screw hole on the sensor itself so that you can adjust it. Anywhere from .8 to 1.0 ohm.
Old October 30th, 2007, 04:39 PM   #3
TENGRAM is on a distinguished road
Re: TPS
what makes you think the TPS has low voltage?
89 GT t5 3.73
www.my5oh.com/
Old October 30th, 2007, 04:43 PM   #4
soon to be fox body
BROKINARROW is on a distinguished road
a bad tps
starting from scratch
Old October 30th, 2007, 05:00 PM   #5
vfast will become famous soon enough
how low? what is the voltage @ WOT
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old October 30th, 2007, 05:02 PM   #6
soon to be fox body
tps voltage at idle shoud be near .39 and wot is 4.84
Old October 30th, 2007, 07:07 PM   #7
IDLE?
t/b closed it should be in the range of .96-.99 car not running
6'ers are for kids
Old October 30th, 2007, 09:36 PM   #8
Originally Posted by vfast
IDLE?
spec is actually .49 to 1.2. best to keep it in a safer range of .8 to 1.0. there is no performance advantage to any specific value as long as it is within spec. at WOT the voltage should be at least 2.71 volts above the closed throttle setting. again, no psecific voltage value.
idle= .49 to 1.2
part-throttle= .04 over the idle setting
WOT= 2.71 over the idle setting
89 GT t5 3.73
www.my5oh.com/
Old October 31st, 2007, 10:18 AM   #9
soon to be fox body
thats fine don't listen to me. i have the specs from alldata that tell me what they are suppose to be. but whatever
Old October 31st, 2007, 01:06 PM   #10
1989 Mustang LX
My computer keeps throwing out the code for low voltage to the tps. I replaced it not long ago because I had the same code and it cleared up for a day or two max. The one I bought was from Advance Auto Parts which may have been my first mistake. I keep reading conflicting post about whether or not the tps needs to be adjusted. Some say it doesn't and others say that it does. I'm beginning to think I should go to Ford to get a replacement and start from there.
Jesse
Old October 31st, 2007, 01:11 PM   #11
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
when you replace it you must adjust it within stock specifications... thats why if you notice when you put it on the holes are elongated so that you can rotate the sensor itself...
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old October 31st, 2007, 01:12 PM   #12
FoxHoss's Avatar
02' GT
BTW... ALLDATA is siiick!!!!
Old October 31st, 2007, 09:31 PM   #13
soon to be fox body
i work with alldata every day and i was trying to help hime out but other people think they know from hear say but i had it right in front of me. and my information comes from dealers.
Old October 31st, 2007, 09:41 PM   #14
sonicblue's Avatar
1990 GT
sonicblue is on a distinguished road
tengram knows his shit...i dont think he was trying to say you were wrong but he has a lot of hands on knowledge and his info has always been spot on
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old October 31st, 2007, 10:52 PM   #15
thanks
i know what the voltages should be because i have read the GUFB (a9l) strategy guide which is an internal ford document intended for the engineers at ford. also most sources for diagnostic trouble codes descriptions show the range .49-1.2 also. i am positive these are the correct values, but sorry if you think i stepped on your toes.
89 GT t5 3.73
www.my5oh.com/
