Stock Vaccum Line Locations
Old October 30th, 2007, 03:57 PM   #1
Speedstang302's Avatar
13.64@101mph
Ok well i removed my GT40 top end and i still have a very small clue to where all the lines connect to there ports...all the vaccum lines attached to intake? and any other..a good diagram would help alot..thanks
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old October 30th, 2007, 04:31 PM   #2
TENGRAM is on a distinguished road
89 GT t5 3.73
www.my5oh.com/
Old October 30th, 2007, 08:13 PM   #3
Rustbelt's Avatar
Rustbelt is on a distinguished road
crap. i guessed right on most of them. i just got the thing put back together too.
Old October 30th, 2007, 09:02 PM   #4
13.64@101mph
Originally Posted by TENGRAM
mine isnt set up like that under neath!! the FPR one is ABOVE the one that goes to the tree. and the pcv valve one doesnt have that hoe on the back...also what is the canister that the far right one goes to? A/C?
Old October 30th, 2007, 09:28 PM   #5
just make sure you find a port for the pcv and FPR, it doesn't matter where as long as they get vacuum. the "canister" vacuum line connects the the Canister Purge (CanP) solenoid and then a vacuum line connects from the CanP to the Charcoal Canister.
89 GT t5 3.73
www.my5oh.com/
Old October 30th, 2007, 09:49 PM   #6
13.64@101mph
well the one on drivers side rear (pcv) i had just plugged, what and where that go to? and the canisters, where are they, cuz i have no a/c stuff...
Old October 30th, 2007, 09:50 PM   #7
13.64@101mph
Old October 30th, 2007, 10:14 PM   #8
the PCV valve that sits in a hole in the rear of your lower manifold needs a vacuum hose attached so that it can vent crankcase fumes.
the charcoal canister is only to vent the fuel tank without releasing vapors to the atmosphere. it should run fine without it as long as the tank still has a vent line attached. the Charcoal canister is a big black square box that normally gets attached to the inside of your passenger side front frame rail, visible from the engine compartment. the CanP solenoid is actuated by the ECM during specific driving situations to allow vacuum from the intake to help draw vapors into the char canister.
89 GT t5 3.73
www.my5oh.com/
Old October 30th, 2007, 11:16 PM   #9
Rustbelt's Avatar
i have my pic i think i got them. what does #1 go to? i have i plugged. #2 was to the canister. is #3 to the egr?
Old October 31st, 2007, 12:16 AM   #10
on my explorer manifold i capped #1. #3 can be used for the EGR Vacuum Regulator solenoid (not directly to the EGR valve) that is located towards the top of the back of your passenger side strut tower. you will also need to find a source for the vacuum line that attaches to the Fuel Pressure Regulator. i don't have EGR so i just used #3 on your diagram for the FPR.
89 GT t5 3.73
www.my5oh.com/
Old October 31st, 2007, 05:13 AM   #11
Rustbelt's Avatar
i'll have to do some mods...... i haven't fixed the timing and idle yet, so it has been hard to spot all the screw ups. thanks tengram, this helped a lot
Old October 31st, 2007, 05:34 AM   #12
Rustbelt's Avatar
i'm not using the smog pump would one of those vac lines work for the fps?
Old October 31st, 2007, 09:43 AM   #13
13.64@101mph
OK..well i know the black box on pass. side you're talk bout..there is a long black hose that is connected to it..
and i plugged the pcv port, good idea? prob not!!!
Old October 31st, 2007, 10:57 PM   #14
unless you have 2 breathers and no tube between the oil fill tube and the TB, you need the pcv to vent the crankcase. the pcv valve and screen are relatively cheap and available at most autoparts stores. or if you have one already just hook a vacuum hose up to it. my2cents anyway
89 GT t5 3.73
www.my5oh.com/
Old October 31st, 2007, 10:59 PM   #15
1987 ford mustang gt
well see when shes done
mine is actually round
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old October 31st, 2007, 11:08 PM   #16
on a fox body? are you sure you're not thinking of the vacuum reservoir, which is a black sphere?
89 GT t5 3.73
www.my5oh.com/
Old October 31st, 2007, 11:23 PM   #17
nevermind i just skimmed through the sentences,thanks fir catching me on that one it dont happen to me often
Old November 1st, 2007, 12:00 AM   #18
no problem, BTDT. on a few occasions i have posted a page worth of advice only to find out later that the original poster was talking about a new edge stang and not a foxbody
89 GT t5 3.73
www.my5oh.com/
Old November 3rd, 2007, 12:55 AM   #19
Rustbelt's Avatar
tengram, i have an empty port on my vac tree could the fuel press reg be attached to that? what about a line from the smog pump?
Old November 3rd, 2007, 01:11 AM   #20
the smog pump (valve) vacuum lines are actuated by the smog solenoids...sometimes on sometimes off, so they would be a very poor choice for using for the fuel pressure regulator. the empty port on the vacuum tree should work ok, or you could just tee into another vacuum line.
89 GT t5 3.73
www.my5oh.com/
Threads Similar to: Stock Vaccum Line Locations
sry to post another topic. question about vaccum? tehdwarvenn 5.0 Mustangs 6 November 4th, 2007 06:40 PM
Vaccum Problems Speedstang302 5.0 Mustangs 2 August 25th, 2007 09:27 PM
Motor Mount Locations GTpwrdCapri Modular Mustangs 4 March 2nd, 2007 08:59 AM
O2 Sensor Locations? Blue98GT Modular Mustangs 7 January 10th, 2007 07:05 PM
O2 Sensor Locations green machine V6 Mustangs 4 March 16th, 2006 10:40 PM
