t5 bell housing
wat size and grade the the bolts that connet the tranny to the bellhousing
85 svo. work in progress
Grade 8 on everything no reasone not to as far as size cant help ya but someone will i whant to say 1/2 but not sure and you can tell they are grade 8 by the 5 points on the head although not all are equal we have a farm and fleet there bolts are shit i can snap a 1/2 grade 8 with a ratchet
I would use grade 8 if possible, but you should be able to find the right Ford bolts at a dealership parts counter. Might cost a couple of bucks more than the local hardware store, but IMHO well worth the extra hassle and money. That's what I would do. Just make sure the thread is right, whatever you do. Also, if I remember right, one of the bolts is a little longer than the others.
I trusted someone that should have known what he was doing to do my clutch a few years back and he stripped one of the holes in the housing using an incorrect bolt with a coarser thread (upper right - try installing a heli-coil in THAT hole without removing the housing!). Moral of the story - use the right bolt and don't trust anyone with your car that you wouldn't trust with your bank account info. |
im doin the work myself i just need the thread size ill double check my chilton and haynes to see if its in there.
Threads Similar to: t5 bell housing
| Tap size for 351w where bell housing bolts up? | 8A_Honda | 5.0 Mustangs | 2 | August 5th, 2007 01:08 AM |
| Taking off stock Air filter housing | RandoGT | 96-98 | 6 | August 3rd, 2007 03:20 AM |
| Thermo housing leaking | sorrowfulkiller | Modular Mustangs | 1 | June 6th, 2007 09:15 PM |
| Chrome Thermostat housing. | jrfan4life | 99-04 | 9 | April 17th, 2007 06:37 AM |
| Stock bell housing question | tony123 | Classic Mustangs | 3 | January 5th, 2007 07:36 AM |
