Speedometer probs!? help please - Page 2
Old November 19th, 2007, 12:06 AM   #21
ryans88gt's Avatar
Originally Posted by sneezingfox View Post
Yes, I am sure I have the right gear. I didn't change it. The only thing I changed was the speedo cable. I just found out however that the trans that I put in is out of a 92 gt. Mine is a 1989. WIll that cause any issues?
There is a plastic gear inside the transmission that drives the gear on the end of the speedo cable. I think they make like 6,7,8,and 9 tooth gears. You probably have a different drive gear in there and need to adjust the gear on the end of the speedo cable to match. They are color coded so if you take the speedo cable out and shine a flashlight in there you should be able to find out what gear is in there.
Old June 11th, 2008, 03:20 AM   #22
Look Ma! My First Post!
1991 mustang hatch 5.0
sacstang916 is on a distinguished road
is this a common problem for this car? i heard alot of 5.0's have this problem.
Old June 11th, 2008, 08:07 AM   #23
1993 mustang lx convertib
saldoggs is on a distinguished road
your speedo is probably bad you should pull the speedo cluster and drive the car around the block and see if the cable is spinning have a friend come with you and watch you will see if its hanging up if the gear in the tranny is bad the you will see the cable skipping when it turns . when the speedo is out you will see where the cable connects you can spin it with your hand you should see the speedo bounce when you spin the piece in the back
Threads Similar to: Speedometer probs!? help please
PC probs.. El_Cangri The Clubhouse 4 July 28th, 2007 02:27 AM
More probs alabamastanger 5.0 Mustangs 1 June 5th, 2007 06:34 PM
Probs alabamastanger 5.0 Mustangs 7 May 30th, 2007 06:30 PM
sig probs. joka187 Feedback Forum 1 May 14th, 2007 12:18 AM
TPS probs Invictus Modular Mustangs 15 November 23rd, 2006 09:17 PM
