NEED HELP PLANNING 86 5.8 MONSTER
View Poll Results: Fuel injected 5.0s or Carbd????
Fuel injection 3 37.50%
Carb 5 62.50%
Voters: 8. You may not vote on this poll
Old November 1st, 2007, 12:06 AM   #1
GeNos86GT is on a distinguished road
Send a message via AIM to GeNos86GT
ok so i got my stock 5.0 h.o f.i motor out of my 86 hb and its parked for the winter. Im painting it all black, tinting the windows, putting black cobra replicas on it and a bbk suspension kit on it and redoing the interior. but enough wit the shit dat dont matter. my engine is a stock engine except edelbrock upper intake plenum and cold air kit. i want a 351 but have a lot of questions about it. I have a set of 351 cylender heads bored and honed but need rockers valves and all that good stuff. will they fit on my engine ??? also im planning on either buying a 351 block and building around it or just boring mine out to 5.8 . which would be better?? fuel injected to carb,,, parts needed ??? cam change??? intake??? also will i need a different trans with the 351s power??? help plz
Old November 1st, 2007, 12:11 AM   #2
1987 ford mustang gt
well see when shes done
you cant bore a 302 to a 351 and my suggestion would be to find a 351w block,and how do you have heads that are bored and honed?????
347, torn apart again.
Old November 1st, 2007, 12:16 AM   #3
my friend gave me some cylender heads that were 351s bored and honed a little . so now i kno u cant bore it out that much should i just buy a 351 block and bore that ???? will it fit to my stock motor mounts
Old November 1st, 2007, 12:20 AM   #4
those heads were ported and polished not bored.And you can not bore your 302 to a 351!!!you can only bore a 302 to a 310.But you could build a 347 stroker which involved notching the cylinder skirts,boring the cylinder walls 0.030 and putting in a stroker kit
Old November 1st, 2007, 12:22 AM   #5
whats a stroker kit??? u got the 347 right hows that run??
Old November 1st, 2007, 12:25 AM   #6
coreyflipp's Avatar
1990 Mustang gt
coreyflipp is on a distinguished road
You're probably refering to port and polish not bore and hone. Are they windsor heads or cleveland. They both will work on the 302 but clevelands take modifications. You can't bore the 302 to a 351 but you can bore and stroke it to 347. If you want a 351 find one from a salvageyard or buy one new if you have $$. You will also need different headers and motor mounts and oil pan and accesory brackets. Jegs has the kit. Carb would be the simplest thing to do. What Jordan said. He must have wrote that when i was typing this.
2002 gt 5-speed
1990 gt 5-speed
1981 Notch Roller
Old November 1st, 2007, 12:26 AM   #7
i am building a 347 right now and i also have a coast high performance stroker kit but heres a link to a scat
http://store.summitracing.com/partde...5&autoview=sku
Old November 1st, 2007, 12:27 AM   #8
actually 5 mins before
Old November 1st, 2007, 01:19 AM   #9
89LX347's Avatar
89LX347 will become famous soon enough
build a 408 stroker
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old November 1st, 2007, 05:24 AM   #10
1965 Mustang Fastback
nba1341 will become famous soon enough
if he bought one of those new boss blocks.....
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old November 1st, 2007, 06:56 AM   #11
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
get a 351 from the junkyard, preferably something in the 1970 era, and get the bored out
stroke it, then put those heads you got on it
then all you need is the EFI stuff and you're set (and that you can get most from the junkyard)
but if you want to buy it all brand spankin new and waste all sorts of money, you can get the crate motor from ford
[SIGPIC][/SIGPIC]
Old November 1st, 2007, 10:25 AM   #12
92Rideagain is on a distinguished road
Get a Boss 302 stroke it to 347 put some good heads on it and call it a day.
Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety.
"Benjamin Franklin"
Old November 1st, 2007, 12:10 PM   #13
Overkill's Avatar
Overkill is on a distinguished road
The '86 is an odd year in a lot of respects, and you pretty much can't bolt anything to it without some kind of major work somewhere else. The stock block is pretty much junk for doing any performance stuff. You can't even change the cam out without replacing or at least flycutting the pistons. If you are talking about bolting the heads and all to the '86 block, you can't use the pistons that are in it. They're forged, but not flycut.
The electronics are junk too. It's a speed-density system as opposed to mass-air, so any performance work you do to it will not be corrected for in the brain. If you make it breathe better you can't add fuel to the mix and the lean mixture will punch a hole in a piston in a heartbeat, if a valve doesn't do it first.
If you upgrade the motor in an '86 in any way past removing the airbox and bumping the timing, you will need to upgrade everything that pertains to the motor, with the possible exception of the ignition. But if you're going that far, I kinda like the idea of the 408 stroker.
Old November 1st, 2007, 01:29 PM   #14
Thewolfman456 is on a distinguished road
Send a message via Yahoo to Thewolfman456
He might be a newbie, but I like his answer and I'll back it up.
Old November 1st, 2007, 04:15 PM   #15
13.64@101mph
depends on how much money he has..if he's rolling in it, i say dart 347 TT FTW..if not find a 351w out of an older truck/ SUV or full size car..
you could easily find a 302 out of an 87-92 mustang, have it sent out to be bored out and hyperfluxed, then get that scat stroker bottem end jordan suggested into it and, there ya go 347 stroker w/ 0 miles..then find either get a trick flow top end kit, build you're own, or find used parts...
but what are you're plans with this car?
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old November 1st, 2007, 08:36 PM   #16
I say fuck it all,he dont need to be building a motor
Old November 1st, 2007, 09:26 PM   #17
13.64@101mph
Im gonna fuck ya'll, im SO horny
yay
Old November 1st, 2007, 10:04 PM   #18
13.64@101mph
yay
Old November 1st, 2007, 10:10 PM   #19
woo hoo im gettin some tonight!!!!!!!!!!!!!!!!!!!!!!!
Old November 1st, 2007, 10:27 PM   #20
13.64@101mph
but w/e
Threads Similar to: NEED HELP PLANNING 86 5.8 MONSTER
NEED HELP PLANNING 86 5.8 MONSTER GeNos86GT 5.0 Mustangs 2 November 1st, 2007 04:33 PM
Bolt-On Exhaust Planning, Etc. Xeremeh V6 Mustangs 4 November 8th, 2006 06:26 PM
monster trucks, nascar, and drag racing stang fanatic The Clubhouse 20 August 20th, 2006 12:26 AM
