engine surging
Old November 1st, 2007, 07:34 PM   #1
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
engine surging
hows everyone doing? ok i have a 1990 5.0 gt with bbk headers, underdrive pully, 3.55 gears and been lowered about 2in. thats all that i know of from the previous owner. lately while im driving i cant stay at a steady speed. it either speeds up or slows down. while its at idle it it surges as well like im gasing it a little and letting off. i thought i may have an intake leak so i replaced the upper intake gasket and the throttle body gasket. i also replace all the hoses under the pletum(sp?) and the pcv valve. now heres the odd part. it only does this while the check engine light is off but when it comes on she drives like a dream. any thoughts?
Old November 1st, 2007, 07:36 PM   #2
13.64@101mph
Re: engine surging
sounds like a vaccum leak somewhere..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old November 1st, 2007, 07:40 PM   #3
chickenbot's Avatar
1990 mustang gt
eventually
where do you recomend to check?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old November 1st, 2007, 08:04 PM   #4
13.64@101mph
spray carb cleaner on everything, pretty easy way to check, also check all the vaccum ports on upper and lower intake, one may have fallen off
Old November 1st, 2007, 10:16 PM   #5
89LX347's Avatar
89LX347 will become famous soon enough
map sensor could also be the problem...that happened to me too
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old November 2nd, 2007, 12:33 AM   #6
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
i have a 78 mustang with a 302 that i went all out on and i have a similar problem. but its not as bad, its just tiny surges when im at cruising speed and i cant figure it out. (its carburated) if anybody has any ideas please help.
Old November 2nd, 2007, 12:40 AM   #7
13.64@101mph
so does the throttle just stick wide open sometimes? also could be you're timing!!!
Old November 2nd, 2007, 01:23 AM   #8
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
engine surging
I had a surging problem and it turned out that my timing was off.
Old November 2nd, 2007, 11:44 AM   #9
BigBlockFairlane's Avatar
BigBlockFairlane is on a distinguished road
Similar stuff, vacuum leak, ignition sytem, set timing, voltage regulator.
Is it duraspark?
http://i95.photobucket.com/albums/l148/supercobrajet/Boostednotch.jpg
Old November 3rd, 2007, 02:43 AM   #10
78mach1's Avatar
no the throttle is completely fine and my timing is set perfect and i have made some adjustments to the timing and it hasnt changed anything.
Old November 3rd, 2007, 02:49 AM   #11
78mach1's Avatar
Is it duraspark?
ya i was thinking vacum leak to but like i told the other guy, the timing is right where it needs to be, but i was thinking, if i take a propane torch and turn it on so only gas is coming out, and i hold it on all the vacum lines, carb, anything with vacum. do you think it would richen it? so i could find it if it is a vacum leak?...cause i have searched high and low for one and i cant find one. and i am running out of ideas
Old November 11th, 2007, 11:47 PM   #12
chickenbot's Avatar
1990 mustang gt
eventually
would a maf going out do this too? what is the stock size as well
1990 gt 5.0
3.55 gears
Old November 11th, 2007, 11:58 PM   #13
white93pony is on a distinguished road
use carb cleaner spray all over intake and check all hoses/vaccum lines
Old November 13th, 2007, 01:31 AM   #14
78mach1's Avatar
hey ya i did it with carb cleaner. i had a small leak where the power brake booster hooks to the back of my carb
thank!~
Threads Similar to: engine surging
Compressor surging. Need new bypass.... Stangtuner General Tech 12 January 13th, 2008 05:40 AM
Surging 5.0....Please help REBELPONY 5.0 Mustangs 28 August 30th, 2007 02:53 PM
gt surging when in gear with brake on or ac on dobermean 99-04 1 August 20th, 2007 10:18 PM
surging idle help jam77 5.0 Mustangs 7 August 20th, 2007 06:45 PM
Engine Surging @ Idle Milner62 General Tech 0 August 22nd, 2006 02:56 PM
