blueprinting
Old November 2nd, 2007, 07:09 PM   #1
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
blueprinting
isnt blueprinting and internally balancing the samthing.....and if so isnt it where all the rotating assembly balanced....the reason why im asking is because im getting my 351w block preped for the 408 stroker kit and someone told me that i should get my block blueprinted....
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old November 2nd, 2007, 09:10 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
they are not the same thing. balancing is for the rotating assembley. blue printing is work done on the block.
Old November 5th, 2007, 02:05 PM   #3
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
When you "blue print a block", a machine shop machines it to the perfect factor specs. It ids good that you using a older block as the will some times lose the tolerance if your using a new block and it heats for the first couple of times. make sute that your machine shop uses torque blocks to simulate the heads being installed.
Old November 22nd, 2007, 02:46 AM   #4
torquecars is on a distinguished road
The two are very similar terms and often used interchangably, but there is a lot more to engine balancing that just balancing the physical compenents - you need to look at dynamic balancing also which addresses compression balance and matching fuelling etc...
Threads Similar to: blueprinting
Stroking, Boring, Blueprinting, etc. MSO General Tech 14 January 7th, 2007 02:53 PM
