#21 |
I wouldnt think it would be as good flow wise as TF, Holley, etc, even if it is ported. if you buy a good intake to begin with, you wont need porting...
#22 | |
THE GT40 IS THE MOST DESIRED MANIFOLD IN THE 5.0 INDUSTRY FOR MILD MODIFIED MUSTANG UP TO 450 HP. THEY RUN OUT OF UMPH AT ABOUT 5300 AND THE HP AND TORQUE CURVE JUST KINDA FLATTEN OUT. THEY ARE SO DESIRED BECAUSE OF THERE LOOKS MORE THAN ANYTHING. A GREAT PERFORMANCE MODIFICATION FOR A MILD CAR BUT NOT RECOMMENDED IF YOUR TALKING ABOUT 331 347 BLOWER N20 TURBO ETC ETC. COMPARED TO THE OTHER MANIFOLDS ON THE MARKET, IT IS SUPERIOR TO ALL THE ENTRY LEVEL SYSTEMS SUCH AS PERFORMER INTAKES, PROFFESIONAL PRODUCT INTAKE, TRICK FLOW STREET HEAT AND HOLLEYS. RPM2 HOLLEY SYSTEM X TRICK FLOW R SERIES. THOSE ARE SUPERIOR BUT YOU WILL NEED MUCH MORE THEN JUST A 302 TO UTILIZE THIS TYPE OF MANIFOLD, OTHERWISE IT WILL BE A BIG FAT DOG DOWN LOW. |
#23 |
the explorer/gt40/cobra manifolds will generally give you better lowend power compared with any aftermarket intake...on the otherhand the aftermarket intakes are better in the higher rpms. if you have a mild (stockish) combo the gt40 intake will work better for you. but with any engine with aftermarket heads and cam the aftermarket intakes would be better.
#24 | ||
1987 ford mustang gt
well see when shes done
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#25 | ||
#26 | |||
I guess it is all personal preference. |
Threads Similar to: custom gt40 tubular intake
| gt40 upper/lower intake manifold | MustangSparks | 94-95 | 1 | July 17th, 2007 04:14 AM |
| GT40 INTAKE | 50COUP332 | 5.0 Mustangs | 6 | March 26th, 2007 10:23 PM |
| Custom Intake Manifolds? | via sin dios | V6 Mustangs | 6 | January 8th, 2007 11:05 PM |
