The Fox Body - Page 3
Old November 5th, 2007, 12:33 AM   #41
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Its ok dont leave I want you in here
Why havent you slept in three days
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old November 5th, 2007, 12:37 AM   #42
baine21225's Avatar
been busy, helping my dad build a big ass work bench and shelves in his garage friday night, last night i was up framing and building my custom rear seat delete in my car to put a "bumpin" system in and tonight i went out to din din with my grandparents and came home and cant stop playing madden
Old November 5th, 2007, 12:38 AM   #43
Drick's Avatar
That good enough for me. Madden online
FX4 Crew
Crew member #1
Old November 5th, 2007, 12:40 AM   #44
baine21225's Avatar
just my season right now, i did a fantasy draft with 4 teams, then traded all the best players to one team ....just beat the pats 98-0
Old November 5th, 2007, 12:41 AM   #45
Drick's Avatar
98-0 damn
FX4 Crew
Crew member #1
Old November 5th, 2007, 01:01 AM   #46
Rustbelt's Avatar
Rustbelt is on a distinguished road
danderson, as you may have found out by now these guys will always help you spend your money! based on my experence so far 89-92. notches bring a premium. verts weigh more. auto or man?
HP is nothing if you cant get it to the pavement. is the $2000 for the whole project or just the engine? foxes are flexy get some sub-frame connectors too.
Old November 5th, 2007, 01:12 AM   #47
Drick's Avatar
I love to spend other peoples money considering I have none of my own . But im working on getting a job MAF conversion cam and intake here I come
FX4 Crew
Crew member #1
Old November 5th, 2007, 01:43 AM   #48
Psychojimmy's Avatar
Psychojimmy is on a distinguished road
Good point, Check your local Craigslist listings for some used wheels and tires that will get some more traction, you can save a good chunk of $ that way! I got a set of Weld Draglites with some 26x10.5 ET Streets for 380 bucks and the both the wheels and tires were in great shape! Then I sold my pony wheels to the same guy for 200 bucks and a 70mm BBK EGR spacer.
'88 GT Hatch, H pipe, flow master, weld draglites ..more to come.
If your car looks like Pep Boys threw up................ You might be a ricer !!!!!!!
Old November 5th, 2007, 09:56 AM   #49
Speedstang302's Avatar
13.64@101mph
dart block..with low like 9 something to 1 if you want that s/c and a trick flow kit and stroked to 331 or 347 you could easily be over 500hp..
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old November 5th, 2007, 11:26 AM   #50
Overkill's Avatar
Overkill is on a distinguished road
Having done it both ways, Rustbelt is right. Power ain't dogsqueeze without traction, and speed kills if you can't stop it or steer it.
Put your first round of $ into stiffening the chassis (the unstiffened Fox is a wet noodle), the second round of $ on suspension and brakes (the older the Fox the worse the brakes) and then start on the drive train.
I've spent years and thousands and I can honestly tell you that any top end (I currently have a port matched Trick Flow Track Heat) will not give you anywhere near 360 HP without doing a bunch of other stuff, most of it either a little or a lot expensive. And whatever you do, don't put anything that makes it breathe better on an '86 or '87 that hasn't been converted to mass-air, or your $2000 will turn into $7000 in one pass.
Put that two grand into the body, tires, suspension and brakes. If the car's got a healthy (not worn-out) stock engine, it won't hook up in it's stock configuration anyway so work on that until you can't make it spin the tires. Then it's ready for more torque.
Anyone that has a $5000 turnkey 347 has cut corners somewhere. Stay away from them. Remember, you get what you pay for, sometimes less, but never more.
1986 Mustang GT
Old November 13th, 2007, 10:59 PM   #51
EscortSportage's Avatar
1989 Mustang GT 5.0
89 GT is the best...and that is why i waiting SO long to buy one (everyone was like get a 91 or 92 same shit..i was like NOPE
89 = 25th years of Mustang
1st all across board MAF
forged pistons
no air bags
and then the bads...
smaller cam
smaller TB
lil bit less HP
but better in long run! im going to eat my friends 88gt alive!
Old November 13th, 2007, 11:13 PM   #52
1987 ford mustang gt
well see when shes done
86 -92 had forged pistons 86 also had flat tops and 93;s had hyperuetectic's
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old November 13th, 2007, 11:28 PM   #53
87foxbodylx's Avatar
1987 Mustang LX
13.9@102.43
87foxbodylx is on a distinguished road
my 87 has no airbags and has forged pistons... only thing it didn't come with was MAF. I personally will never buy a MAF unless its used for forced induction...
HONDA: Hold on, Not done Accelerating
A girl's legs are her best friends, but the best of friends must part.
LIVE Tag- foxbody87
http://i4.photobucket.com/albums/y134/Jswigs16/Betterversion.jpg
Old November 13th, 2007, 11:30 PM   #54
ujslost's Avatar
i dont suggest putting the SC on the stock intake, cam and heads. they just wont breathe as good as that SC needs them too. Get the trickflow kit. Then suspension, then the SC or either suspension then the trickflow kit.
Old November 13th, 2007, 11:33 PM   #55
1989 Mustang GT 5.0
speed density is garbage, and i heard it runs like crap after u put some aftermarket goodies in it, EFI MAF is so much more efficient and u can fine tune it better
Threads Similar to: The Fox Body
will this body kit fit my gt? outlawedstang 99-04 20 November 5th, 2007 03:09 PM
NOW FOR BODY FLEX ON MY ON FOX BODY FLEX MACHINE keith0s 5.0 Mustangs 65 October 25th, 2007 09:54 PM
Fox Body Brenda The Clubhouse 30 September 10th, 2007 06:27 PM
Body Kit or Body Part.. hmm 04musclestang V6 Mustangs 6 January 7th, 2007 07:29 PM
will a 94' to 98' body style rear end fit under a fox body frankenstein 5.0 Mustangs 3 July 13th, 2006 09:53 PM
