to my breaking point....help!!!!
so we replaced the head gaskets on my 347 last night. got everything together today and fired the car up.
it acts EXACTLY like it did before. wont idle, steam comming out of the oil filler neck, and once the temp starts to climb, it shoots to 200 and continues to climb. I shut the car off immediately when it hit 200. im freaking lost. I have no idea what the problem could be. I guess the next step is to check compression in each cylinder and go from there. |
Big timin' in a small town
Damn I dont know what to tell you man. I dont think it would be head gaskets something else.
oh and are you turboed or supercharged and what brand and how much did it cost
95 Mustang GT
did you have the head checked when you replaced the gaskets to make sure it was not cracked or warped . I have had cracks so small you cant see them put they are there....that would be my next step bro
You did have everything just machined and the motor was built not to long ago. Thats sounds like it could be something wrong there like a cracked head now or cracked block. How long did it run good before this started
Do you have air trapped in the system? Did you check the block and head for cracks and straightness? Did you do a compression check before you tore it down?
#7 | |
I did not pull the engine and check the block. looks like maybe I should have. I did not check compression before the tear down because the dyno tuner said it "lifted a head" while being tuned. and would having air trapped in the system cause steam to come out of the filler neck? |
also a leakdown test... ive seen were theres a hairline crack in the cylinder wall that caused the same symptoms, pluse the leakdown test will also cover a compression test at the same time
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
#9 | |
1990 LX hatch
My crank case steams at the slightist ammount of moisture. Burping the system is extremely important for the cooling system to work properly. Once I dident have my overflow hooked up right and it made the temp crazy.
ok guys. stupid question.
on the block, and heads, there are two pair of water jackets on each end. if you hold the head gasket and look at it, only ONE end has the holes for these jackets. im assuming this could be my problem. did i put the head gasket on backwards? |
#12 | |
#13 | ||
im a dumb ass.....lol I had the gaskets on with the two water jacket holes towards the front of the block instead of the rear. cometic gaskets dont say anything on them about top or bottom or front or rear. I just made a dumb rookie mistake. should have had my mechanic put it back together instead of doing it myself. a very time consuming and expensive learning experience.
na man, it's good you did it yourself, now you know what not to do again, and can maybe help someone else if they ever do it......and you wont do it again on a more expensive project....one would hope
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
yup mess up once wont do it again....guaranteed
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA 3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH |
Threads Similar to: to my breaking point....help!!!!
| Breaking News | GTsetGO | The Clubhouse | 1 | October 29th, 2007 10:02 PM |
| breaking loose bad going into second. | GreenFaleen | V6 Mustangs | 19 | December 29th, 2006 01:23 AM |
| Power Breaking a 5 Speed. | jerb43 | 96-98 | 6 | October 16th, 2006 05:58 PM |
| Under Breaking... | jessy_is_rad | V6 Mustangs | 4 | October 10th, 2006 12:31 AM |
| Breaking News! (Car Show) | WAVEBYE | Modular Mustangs | 2 | October 7th, 2006 11:54 AM |
