Very Hard Clutch breaking cables HELP!
Old November 4th, 2007, 01:04 AM   #1
terryhowellus is on a distinguished road
I bought a 192 LX 5.0 that has a Tremec 3550 with some sort of HD clutch. The peddle pressure is very hard. Almost to the point it hurts to push on a day my knees are not working good. I broke 3 HD Zoom clutch cables.
I have checked by binds and see nothing wrong. The cable appears to be routed fine. Could there be a problem with the clutch itself. I was going to replace the clutch with one that has a software peddle pressure.
Does anyone know of a good street clutch that has lighter peddle pressure?
Whats weird is, I broke another cable tonight and the clutch cable dust cover came flying off. It shot out under the car like a rocket with a loud bang.
I think the original owner out a crazy hard strip clutch in it.
Old November 4th, 2007, 01:05 AM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Centerforce dual friction.
Old November 4th, 2007, 01:24 AM   #3
is there a cable that won't break with this clutch
Old November 4th, 2007, 02:08 AM   #4
89LX347's Avatar
89LX347 will become famous soon enough
throwout bearing maybe?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old November 4th, 2007, 02:44 AM   #5
TENGRAM is on a distinguished road
the OEM clutch cable that maximum motorsports sells is far superior than most aftermarket cables. see the difference:
also, where is it breaking at? sometimes the sharp edges on aftermarket clutch quadrants cut into the cable leading to breakage.
89 GT t5 3.73
www.my5oh.com/
Old November 4th, 2007, 10:39 PM   #6
The first cable did break due to a clutch quadrant that wasn't installed properly. The quadrant actually cut the end of the cable off. I corrected this problem by realigning the quadrant.
The next 2 cables broke on the other end. One cable had the basing break apart and another the end came off.
I am sure it is the clutch that is in the car. Is there any clutch that is high performance and has light peddle pressure? Would the Centerforce dual friction fall into this category.
Old November 4th, 2007, 10:49 PM   #7
yes.
89 GT t5 3.73
www.my5oh.com/
Old November 5th, 2007, 04:31 PM   #8
I decided to purchase the FMS King Cobra Clutch today. It is a diaphram clutch and claims to have 10% less peddle pressure.
Old November 5th, 2007, 04:31 PM   #9
Old November 10th, 2007, 10:43 PM   #10
I solved the problem with the hard clutch. The clutch and pressure plate themselves were bad. Also, the pilot bearing in a million pieces when I removed the pressure plate. Overall the worn clutch was the major problem with hard peddle pressure.
The new king cobra clutch works great. Although, i changed the rear seal due to a leak and now it leaks even worse. I fear I have to take it apart again.
terry
Old November 11th, 2007, 12:35 AM   #11
ryans88gt's Avatar
you may need to quick sleeve the crank journal if there was a nick in it (or you put one in it)
Threads Similar to: Very Hard Clutch breaking cables HELP!
Breaking News GTsetGO The Clubhouse 1 October 29th, 2007 10:02 PM
cables skid6 5.0 Mustangs 2 June 21st, 2007 02:08 AM
JBA power cables work with Screamin Demon? singe V6 Mustangs 7 February 6th, 2007 10:07 PM
Under Breaking... jessy_is_rad V6 Mustangs 4 October 10th, 2006 12:31 AM
Clutch pedal hard, now its just gettin annoying 97TunedMustang 96-98 7 August 17th, 2006 01:28 PM
