Fox Junkyard Swapable Parts
Old November 4th, 2007, 07:36 PM   #1
HMUSN's Avatar
iTrader: 9 reviews
just an FYI for the budget builder.
Electric Fans
MkVIII – 93-96 p/n – F3LY 8C607 A
97 p/n – F7LZ 8C607 AB
98 p/n – F8LZ 8C607 AA
94-95 Mustang GT or V6
89 OR NEWER 3.8L V-6 taurus fan
3G Alternators
94-95 Mustang V8
94-98 V6's
Other cars with the 3.8L motor in it. 5.0L cougars with the 94-95 style motor and others.
There are a lot of car with the 3g alt that will fit. Late 90's is when Ford switched to the 4G alt.
Make sure you clip the small white stator plug and take that also. You will need it.
Mid 90s taurus or escort. Says 130A on the back etched into it.
93-96 Tarus 3.0 V-6 (non SHO)
94-96 Mustang 3.8 V-6
94-95 Mustang 5.0
94-96 Thunderbird 3.8 V-6 (non SC)
95-96 Windstar 3.0 V-6 (most are 3.8's)
93-96 E/F series Trucks/Vans 4.9 L6*
96 Sable 3.0 V-6
94-96 Cougar 3.8 V-6
*Probably the best one if you can get it (should be easy to find, too) is off the E/F series...this series uses a threaded top ear like the stocker on the Mustang....E/F series with threaded ear uses metric bolt. ALSO, make sure the E/F series is 130 Amps and NOT 95. For all other cars listed above 130A is only option listed.
24 lbs. Injectors
93-98 Lincoln Mark VIII 4.6L DOHC
95-up Lincoln Continentals 4.6L DOHC
'03 Lincoln Aviator 4.6L DOHC
F-350 with the V10 engine
7.5L 460 V8 trucks
5.4L DOHC Navigator
Intakes
The 5.0 explorer intake was the same from 96-01.
96-01 Intakes are spin offs of the Cobra Intake.
Heads
Explorer Heads:
Early heads 96-98 models are GT-40 (same as 93 cobra )184,154 valves
late heads from 99-01are GT-40P (angled plug)
184,154 valves , 58cc. Chambers
Throttle Body
Explorer 302 - 65mm TB
You must swap out the throttle shaft and arm from the stock mustang TB.
Brakes Rear
Disk
87-88 Thunderbird Turbo Coupe/93 Cobra
85-91 Lincoln Mark7
Brakes Front
SN/95 spindles and calipers 94-04 V6/GT/Cobra
73mm single piston caliper from Lincoln MkVII.
5-Lug Axles
Driver side ranger axles or passenger side aerostar axles
'83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles (29-5/32")
5-Lug Rotors
84-91 Lincoln MkVII
Master Cylinder
'94-98 V6/GT
'99 V6
Misc.
Escort GT seats (20-25lbs lighter than mustang gt/lx seats, more comfortable, bolt up to the mustang seat rails, and look like the recaro style 85 gt's but much easier to find)
The small starters come on 92/93+ 302's in almost every Ford car and truck that came with the 302.
Old November 4th, 2007, 07:52 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
good find!
Old November 4th, 2007, 08:01 PM   #3
1965 Mustang Fastback
nba1341 will become famous soon enough
oldie but a goodie hehe
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old November 6th, 2007, 04:19 AM   #4
lugnutz08 is on a distinguished road
thanx hm you just compiled a bunch og mags for us!!!!
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA
3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH
Old November 6th, 2007, 10:55 AM   #5
13.64@101mph
all 29 of this guys post are useless..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old November 6th, 2007, 12:29 PM   #6
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old November 13th, 2007, 11:55 PM   #7
EscortSportage's Avatar
1989 Mustang GT 5.0
that is a keeper! i own an Escort GT hmmm...
Old November 14th, 2007, 12:35 AM   #8
ujslost's Avatar
Originally Posted by HMUSN View Post
Misc.
Thats what I have, I didnt know they were lighter though, but makes sence because they dont have the lever on the back of the seat to lean it forward, you actually have to recline it forward all the way on the side. Also they dont have the pull out knee section. Which I have no clue as to why ford ever used seats like that, I have yet to see anyone actually use them.
Threads Similar to: Fox Junkyard Swapable Parts
Parts reviews for aftermarket mustang parts... topflitecop21 Modular Mustangs 3 February 22nd, 2009 11:18 PM
Junkyard Youngin V6 Mustangs 3 July 30th, 2007 12:14 PM
Junkyard Search For PI Components 98gt 96-98 11 December 3rd, 2006 06:34 PM
Where to get parts Wilson00V6 V6 Mustangs 18 November 28th, 2006 09:21 PM
