are 4 pin vs 5 pin relays the same
Old August 17th, 2006, 11:18 AM   #1
OTreborO is on a distinguished road
Ford uses a 4 pin relay for my 89-90 fuel pump and ecc. Autozone provides a generic relay with 5 prongs.
Has anyone replaced a 4 prong with a 5 prong. I realize the 5th prong in the harness is not connected, but am concerned if the relay will actually work or if I need a Ford part.
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old August 17th, 2006, 04:28 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
should be no problem....as long as pin apportioning is the same
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 17th, 2006, 04:37 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The 5th pin is most likely an extra power out and probably labeled 87a. It will work fine.
Old August 21st, 2006, 01:24 AM   #4
F3R
F3R is on a distinguished road
A 4 pin is a normally open relay an a 5 pin relay is normally open an a normally closed.
Threads Similar to: are 4 pin vs 5 pin relays the same
Relays wraitherx 5.0 Mustangs 10 December 10th, 2006 01:15 PM
