351 Windsor or Cleveland
I'm looking to have a 351 n/a motor built over the winter for a future 1/4 mile Stang project. My motor guy has a few clients that have done 351's, stroked, etc. and they are pushing 800+ hp fairly easily.
However, there is no real consensus on Windsor vs. Cleveland heads. Questions: Which are better....Cleveland or Windsor? What mod's would you do to the motor? We have a realistic budget for the motor of $$6-8k. Thanks in advance! Newt |
#2 | |
13.64@101mph
Re: 351 Windsor or Cleveland
i'd say do a 351w stroked to 393 or 408.. heads, cam, intake carb, fuel, ignition etc.. for that 351w
The Razor's Edge
after market heads...
So are you telling me that the Windsor is better than the Cleveland?
I talked to 8 or so of the people that have used this performance shop for their 351 builds.....all went 408, (4) are Cleveland fans (4) are Windsor fans. What is the true difference in the head design between the two and how does the aftermarket address their shortcomings? |
#5 | |
13.64@101mph
#6 | |
The reason each engine was given its name had to do with where it was manufactured; either Cleveland, Ohio, or Windsor, Ontario, Canada. Although both engines have the same bore and stroke dimension and feature the same cylinder head bolt pattern which allows their cylinder heads to interchange with each other, they do use a different camshaft and have a different firing order. While it may not be readily apparent that the Cleveland features larger cylinder heads, it's the Windsor that uses larger 17mm spark plugs versus the Cleveland's smaller 14mm spark plugs. According to noted engine expert, Ray Bohacz, "the 351W was considered a workhorse engine that was designed for low-speed torque, while in contrast the 351C owes its lineage to the Boss 302." |
The Razor's Edge
302's a windsor......
1965 Coupe
the boss 302 is a boss!
13.64@101mph
and you're both
i say just do the windsor more common...i think that the cleveland heads being a little bigger should make no difference..just fine a new block or one from about 68-72..those are the best years, strongest ones..
#10 | |
is he using a new or used block?
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#12 | ||
We are planning to spend approx. 17-20k on the entire build. I am partnering with a mechanic friend who has been racing cars in various aspects for 20 plus years. He has had some 8 second cars but always with a power adder. This time, N/A What type of dollar for the 8-900 hp mark? Thanks, Newt |
#13 | |
My business will be sponsoring the build and a friend will be building along with me when I get time. Getting good advice from everyone....both here in the forum and around town.....trying to make wise decisions upfront so I know what I'm in for in the long run. |
if its sponsored then why go used.....get a dart!!!
#15 | |
Just looking at all options before I pull the trigger........ |
#16 | |
Understood.
Trying to figure out whose telling the truth here in my town. The one guy I spoke to today showed time slips of 9.2 in 1/4 mile with 408 Dart built by the guy I was going to use to build mine. Said he makes 800 HP and he showed me the bill for the motor work...........$7600 bucks! |
Billy Weston
double post............
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
Billy Weston
I may have the stuff to help you get started.......
Stock, filled 351 block bored to 357 c.i. 10.5:1 Wiseco Pro tru flat top forged pistons Forged I beam rods Stock 69 351 crank Manley Pushrods Comp Valve springs and Rockers Comp Retro Fit lifters Comp XR294RF-HR Cam Edelbrock Victor Jr 70 CC heads FMS red on black valve covers Milodan 7 Qt Pan Edelbrock Victor Jr intake The motor was just freshened up less than 50 miles ago, fresh hone, new bearings, rings.... I'm parting the car out now because I acquired a 03 Cobra.
#20 | |
Threads Similar to: 351 Windsor or Cleveland
| has anyone put a Cleveland 351 into an SN95? | dasfonzie | Modular Mustangs | 9 | December 31st, 2009 02:46 AM |
| 1970 351 cleveland | mattsstang | Classic Mustangs | 8 | January 19th, 2007 10:54 PM |
| 351 cleveland | ih8chevy | 5.0 Mustangs | 15 | December 8th, 2006 03:26 PM |
| Cleveland Heads... | 81 Merc. Capri | 5.0 Mustangs | 3 | October 16th, 2006 06:49 AM |
