1988 Mustang GT Vert
Front Passender Side Squeak
The front end of my 88 Vert squeaks, it started off really quiet, I got all new shocks and struts put them on, and it's still there I dont know wat it is. It usually squeaks when I turn left or if i hit a bump or anything... Thanks
Big timin' in a small town
Turning and hitting bumps. Thats your ball joints. Check them out
how do I check them?
#4 | |
hes right i just had to do that 2 weeks ago and replace inner tie rod
Alright thank you guys I will check that out Thanks
Now I have another squeak coming from the the left side somewhere, its a squeak when I drive it sounds like the front brakes, so I cleaned them with brake cleaner and then sprayed brake disc quiet on them, and they were find for a while now they squeak again... Could it be the the drums, I dont apply the brakes and it still squeaks, when I apply them it goes away Thanks
all motor
92 coupe
9.94@136.40
u probly need new new pads. look and see if the squeek is from the metal warning tab on the pad
it would squeak even without the brakes on?
95 Mustang GT
yes it will squeal more with out them on and go away when you hit them they are actually called squealers they are metal tabs attached to your pads that when your pads wear down too far they make noise to let you know to replace the pads before you wear out the drums or rotors and mess them up...keep going and you are going to be metal to metal and tear shit up
What are the best Brake pads you guys think I should get? Thanks again and when I toke them off they didn't look that worn out..
anyone?
Replaced my brake pads because I thought that was the problem, and it wasn't I still have the squeak on the left side that goes away when I press the brake.. Any Help?
Threads Similar to: Front Passender Side Squeak
| Clear Front Signal and Rear Side Marker Lenses - Bulbs | Geezer | 2005 - 2010 | 6 | July 6th, 2010 02:16 AM |
| Sound from front passenger side | RandoGT | General Tech | 5 | November 16th, 2007 04:55 AM |
| passender side manifold | VSR13 | V6 Mustangs | 10 | October 31st, 2007 02:01 AM |
| Creaking from front driver side | Hunt_chevs | General Tech | 0 | October 3rd, 2007 08:14 AM |
| Car leaking water front drivers side | Timmano | V6 Mustangs | 5 | May 23rd, 2007 01:39 PM |
