91 lx vert
heads question
im building a 85 5.0 motor to put in my 91 vert it has the old e6 heads and im wanting to put the e7 heads off of the newer motor on the 85 will i have any problems with the valve to piston clearence on the 85 motor has a e303 cam in it and does anybody know about porting the e7 heads i was told to grind off the egr bump on the exhaust side any help would be appreciated thanks and keep this forum going i read it everyday it helps alot
The Razor's Edge
i think you would be ok....
They should work fine. Check valve to piston clearnace to be safe. Leave the EGR bumps. The gain is minimal and the time it takes to grind the bumps out and recontour the port will take several hours. You'd be better off buying a set of GT40P heads if you want a better flowing head.
Threads Similar to: heads question
| AFR Heads Question | javier351lx | 5.0 Mustangs | 20 | September 16th, 2007 10:38 PM |
| Question about heads. | GTSilver | 99-04 | 2 | October 22nd, 2006 02:15 PM |
| Question about stage 3 heads and better cam | Easy04_jm | V6 Mustangs | 0 | October 19th, 2006 01:56 AM |
| Question (Cracked Heads) | zeroarrn | V6 Mustangs | 5 | October 14th, 2006 03:06 PM |
| Question About Heads | White2000GT | 99-04 | 7 | September 28th, 2006 12:13 PM |
