Vacuum lines
Old August 18th, 2006, 10:04 AM   #1
blackhd is on a distinguished road
Vacuum lines
Greetings all,
I am new to this site but have been reading and see there is a wealth of knowledge here. I have a 88 gt which will only blow air out of the defroster. I am not getting any vacuum to the inside switch. I am fairly sure the vacuum line goes inside the car on the passenger side. Any suggestions on which line it might be?
Thanks in advance
Old August 19th, 2006, 11:03 PM   #2
Bill is on a distinguished road
i have that same problem. there should be a yellow hose underneath the dash on the driver side you need to put back on the vacuum motor.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old August 20th, 2006, 11:45 AM   #3
reply to vacuum lines
Thanks for the reply. The defroster vacuum motor is connected properly. I don't have any vacuum to the control switch which operates all of the vacuum motors. Does anyone know where the vacuum tank is located?
Thanks
Old August 20th, 2006, 12:06 PM   #4
dcraig8 is on a distinguished road
i know on my 94 the canister is located just aft of the right front inner fender well splash shield and the vacuum ball is located just aft of the left front fenderwell splash shield. im not sure yours will be the same
Threads Similar to: Vacuum lines
Fuel lines JBIGBOOTSY 5.0 Mustangs 2 August 31st, 2007 07:10 PM
A/C lines kwill5 99-04 0 August 24th, 2007 12:07 PM
vacuum lines terribleonexx88 5.0 Mustangs 2 October 19th, 2006 02:18 PM
Hard Plastic Vacuum lines OTreborO General Tech 4 May 19th, 2006 06:38 PM
vacuum lines 88stang 5.0 Mustangs 11 April 4th, 2006 04:16 PM
