Discussing B303 Cam in the 5.0 Mustangs Forum. I recently acquired a 92 fox with a 306. The guy that sold me the ...
Old November 7th, 2007, 12:51 PM   #1
MM's Mad Scientist
2003 GT
Street Fast 16.9@76MPH
B303 Cam
I recently acquired a 92 fox with a 306. The guy that sold me the car says it has a B303 cam. I looked up the specs for the cam and I am a little confused. Does this cam have 107 degrees of lobe seperation?- WTF?
After looking at the specs, I don't really understand what this cam is designed for. It has a real choppy idle (which sounds great), but the powerband in this car is weird. It's like the car doesn't come into it's powerband until mid range, but it doesn't seem to have much top end. Is this cam possibly to blame for the strange powerband? It has E7 heads with 1.7 rockers BTW.
Old November 7th, 2007, 01:08 PM   #2
MM's Mad Scientist
2003 GT
I wrote the wrong thing down in the first post. The motor has 1.6 ratio rocker arms.
Old November 7th, 2007, 01:11 PM   #3
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
The B303 cam has a 112 lobe separation. The narrow powerband is the cam. The B303 is known for it.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old November 7th, 2007, 01:17 PM   #4
MM's Mad Scientist
2003 GT
Darrell, what cam would be good swap for this motor? I like the choppy idle, but I would enjoy some performance from it as well. Will a comp 286 work in this motor without PTV issues?
Old November 7th, 2007, 01:24 PM   #5
Tony_90fox's Avatar
Changing the cam would be pointless. In fact, it is just about pointless to have a B303 in there now...Obviously the guy did it for the sound ONLY... Get a nice set of heads and intake before you go swapping the cam AGAIN.
393 dropping in a foxbody near you, very very soon
Military Crew
E-3
Combat Engineer
Old November 7th, 2007, 01:28 PM   #6
MM's Mad Scientist
2003 GT
OK, help me out here- I have never been a Ford guy. My 03 was the first Mustang I have ever really been into, and it is nothing like the SBF. Everything I have built in the past was Chevrolet. I forgot to mention that the car has a holley 750 and an Edelbrock dual plane intake. Maybe I should just go back to proven methods- A built 355.
Old November 7th, 2007, 01:33 PM   #7
MM's Mad Scientist
2003 GT
Here's the car BTW:
Originally Posted by 92rumblefox
1992 LX Hatch, 100k+ chassis miles
1993 302 block (306ci), 11k+ miles on rebuild
FRPP Forged pistons
Cast crank
I-beam rods
E7 heads
SVO B351 1.6 rockers
Edelbrock Performer RPM/302 manifold
Holley 4160C 750cfm carb (vac. secondaries)
Mallory Dual Point dist.
MSD 8.5mm SuperCon wires
MSD 6A controller
Flowtech tuned headers, 3" collectors
Dual Flowmaster 40 series, no crossover pipe
BW T5
Hurst shifter
FRPP King cobra clutch
Steeda billet clutch quadrant
Billet firewall adjuster
FRPP Alum. Driveshaft
FRPP 3.73 gears
Brand new Perfection (sub division of Zoom) flywheel
Grant GT steering wheel
No interior, partial dash (fiberglassing work in progress :thumbsup: )
Two original seats
Battery located in hatch, sealed/vented box
Optima 720cca with an external cutoff switch on the right rear
Dual Imperial electric fans
Electric fuel pump
3rd gen 130A alternator conversion
Summit Star wheels (weld pro star knockoffs)
Mickey thompson Sportsman S/Rs in the rear
Moroso DS2's in the front w/ no tread
Old motor shot, just after the carb. conversion
Old November 7th, 2007, 01:33 PM   #8
Tony_90fox's Avatar
Nah, a 306 is nice man...Just get a good top, in your case, just heads/cam, some nice pushrods. seems like you have a decent carb (i dont know much about carbs though)
I was just saying, that cam with a stock motor is just worthless...It is used for sound only and no performance in your case. Get a pair of nice heads and a better cam and you got yourself a nice motor...
And i am not dogging the B303, that is what i am running, but with ported GT40 heads, ported explorer intake, etc etc...
Military Crew
E-3
Combat Engineer
Old November 7th, 2007, 06:19 PM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
I'd put some heads on before I put lexan in. IMO.
Originally Posted by HELLRAZR94
what up pussy lets stop talking shit i would love for your pussy ass to come to cali so that i can show you what im about, when you get here let me know and i will come to you fag
Old November 7th, 2007, 06:20 PM   #10
JBIGBOOTSY's Avatar
1990 LX hatch
You don't have a chute on that thing do ya?
Old November 8th, 2007, 07:07 AM   #11
MM's Mad Scientist
2003 GT
I just got it. I didn't do all the "upgrades". No, I don't have a chute.
Old November 8th, 2007, 04:53 PM   #12
ryans88gt's Avatar
That carb is pretty big for a 302, you need more like a 600 or 650 for a 302 if you want good off idle power.
Put a set of aluminum heads on there and you will notice a huge difference.
a 355 is a proven turd, not a performance solution. The only thing good about it is that it is dirt cheap, so when it breaks you can replace it cheap. A ford 351w will hold about 800 hp with a stock crank block and pistons (rod upgrade only)
Old November 8th, 2007, 05:59 PM   #13
Speedstang302's Avatar
1989 Mustang LX 5.0
12.86@ 111mph
+1 that would run alot better w/ a holley 650 or demon 650..a custom cam and a nice set of aluminum heads, those heads are doing that thing no justice..and plan on replacing those shitty flowtech headers soon..they suck...
1989 Mustang LX 5.0
Stock w/ F303 cam and 1.6 Roller Rockers
BBK Shortys, BBK o/r H, Flowmaster Super 44s
"The LS1 was subject to a paternity test!!! The results are back....03 cobra you are the Father!!!!"
Old November 8th, 2007, 07:11 PM   #14
MM's Mad Scientist
2003 GT
What the hell are you spewing out of your keyboard? The last 355 I built cost me about $2500 and went a 6.93 1/8 in a 3000 lb. Camaro. Don't go thinkin that the Ford motor is the king just because you have one.
Old November 8th, 2007, 07:37 PM   #15
JBIGBOOTSY's Avatar
1990 LX hatch
I'd have just stuck with that then. Most the guys on here have tried other cars, and makes. Dont think that your 355 is the king cause you got E7's and a 750. A bad combo is a bad combo, 355, 302 or whatever. You need wheelie bars.
Old November 8th, 2007, 07:50 PM   #16
MM's Mad Scientist
2003 GT
Let me say again- I traded for the car as is- I have $800 in this car. If I didn't like the Mustang, I wouldn't have it, but I would like to be some what cost efficient with this car. I have gotten use to spending rediculous amounts of money on the mod motors for less than stellar performance.
Anyway, does anybody know where I could find a tubular K-member that is already set up to accept a small chevy motor?
Old November 8th, 2007, 08:13 PM   #17
sloppyjosey's Avatar
Talking
you don't need a custom K-member, just mounts. and a good head examining.
"supernatural aspiration"
Old November 8th, 2007, 08:30 PM   #18
MM's Mad Scientist
2003 GT
I'm just thinking right now.
Old November 8th, 2007, 08:33 PM   #19
i know youll make the right choice
Old November 8th, 2007, 08:35 PM   #20
Feb 08 ROTM
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
For you Chevy haters, this car has a 355 and runs 8.0s
Threads Similar to: B303 Cam
B303 or E303?? 92mustanglx 5.0 Mustangs 13 May 29th, 2007 06:38 PM
B303 cam homebrewed 5.0 Mustangs 21 March 9th, 2007 12:07 AM
b303 cam with 1.72rr's bigbadtalontsi 5.0 Mustangs 5 January 16th, 2007 06:36 PM
