Discussing help on shift kits in the 5.0 Mustangs Forum. i kno stupid question a shift kit does what exactly to my car does it ...
Old November 8th, 2007, 09:34 PM   #1
help on shift kits
i kno stupid question a shift kit does what exactly to my car does it give freedom to shift between gears all i want or or does it tighten up my shifts or both ?? any info would be very helpful thanx guys
Old November 8th, 2007, 09:42 PM   #2
ive heard it described as like a manual transmission without the clutch ....i could be wrong
Old November 9th, 2007, 11:31 AM   #3
Hourofpain's Avatar
1998 Mustang Gt
14 MPG
Ill pm you some links later.
but
a shift kit strengthens your trany up as well as providing a better shift
for a transmission shifter
I recommend B&M
i have some good links at my house for tranny kits.
a low end basic kit wil run you a little under a 100
now a really good one that can run you 230
ill pm you later
1998 Mustang Gt
4.10 Gears...Stage 3 Clutch...PI Intake Manifold...Hurst Short throw...Underdrive pulleys...Bassani X Exhaust...Strut Tower Brace...Screamin Demon Coil Packs and livewire Ignition wires...Rear Drag Springs
Old November 9th, 2007, 11:33 AM   #4
MM Ninja / Site Moderator
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Boosting shift pressure with a tuner gives the exact same effects as a shift kit. just throwing that out there. then grab a B&M shifter and your good to go.
Old November 9th, 2007, 11:49 AM   #5
Hourofpain's Avatar
1998 Mustang Gt
14 MPG
Not exactly.
Upgrading all the parts inside the transmission with a high quality trans kit and then adjusting with a tuner is a much better idea.
you want to upgrade the stock parts inside the valve body.
your right that itll give itt he same effect.
But it cant increase the durability and strengthen your tranny up
1998 Mustang Gt
Threads Similar to: help on shift kits
Info on Shift Kits GreenFaleen V6 Mustangs 37 November 27th, 2008 03:05 PM
Shift Kits? poisonstallion95gt 5.0 Mustangs 9 October 3rd, 2007 04:09 AM
Shift kits for an auto mrnewall 99-04 1 May 7th, 2007 08:43 AM
Shift Kits 95wip 94-95 6 April 27th, 2007 11:09 AM
AOD Shift Kits man_of_war2081 99-04 8 September 29th, 2006 08:36 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
