Do I really need an inline fuel pump??
Old November 9th, 2007, 08:37 AM   #1
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
So I've just about picked up the last of my stuff to get my car finished up in the spring.
Steeda is recommending I get a BBK inline fuel pump for my setup. I already have a 255 Lph pump in the tank, how would an inline pump pull any more fuel to the motor?
My setup will be TFS Street Heat Heads w/ Stage 1 Cam, and I'll be cranking my KB up to 9 or 10#.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old November 10th, 2007, 12:11 AM   #2
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I think it's just there to help support the fuel demands of the extra boost. Im going to be turning up the boost on my novi and adding 42 pound injectors and i was told to add an inline too.
Old November 10th, 2007, 12:22 AM   #3
ryans88gt's Avatar
it will not get any more fuel to the motor, but it will keep the fuel pressure from dropping when fuel consumption goes up.
Threads Similar to: Do I really need an inline fuel pump??
fuel pump musclepony Classic Mustangs 5 August 17th, 2007 06:04 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
Advice on inline electric fuel pumps 83 5.0 5.0 Mustangs 4 November 28th, 2006 06:26 PM
Fuel Pump Help 1WLDSTANG Classic Mustangs 1 November 18th, 2006 01:10 PM
