Best Disckbrake Rear For 88 Mustang
YO PEOPLE WHAT UP HOPE EVERYTHING IS ALL GOOD WELL I JUST HAVE A QUESTION BOUT REAR ENDS OK GET URE MIND OUT OF THE GOTER
I WANT TO KNOW WHAT KIND OF DISK BRAKE REAR I CAN USE IN MY 88 LX 5.0 IT HAS A302 WITH A T5 TRANY IN IT SOME ONE TOL ME I CAN USE THE TUNDERBIRT REAR BUT I'M NOT SURE ANY HELP WOULD BE GREATLY APRISIATED TANX
![]() SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$% |
I think you'll find what you need to know here...
http://mjbobbitt.home.comcast.net/mustang/5lug.html |
#3 | |
PS: this pic is not my car. |
TANX GUYS FOR THE INFO THERE IS LOT OF STUFF IN THE SITE I'LL HAVE TO GO TRUGH IT A FEW TIMES WHAT WOULD U GUYS RECOMEND IF I'M GOING TO USE 93 COBRA RIMS AND HOW WOULD I KNOW IF IT IS A TURBO CUPE REAR DOES IT HAVE A PART NUMBER ON IT TANX FOR THE HELP PRECIATED... MUSTANG FOR LIFE..........
11.47@120.58
If its not a turbo coupe rear than it isn't disk brakes.
#6 | |
a T-bird rear is about 2" wider than a mustang rear. I have an 86 t-bird as well and I used a rear out of a mustang in it and it is narrower than the original 7.5 so just swap the brake parts it will be less work.
1991 GT Vert w/stuff
On my 91' convertible I swapped out the rear-end from my friends 95' coupe. I also took his 17' wheels with 245/45ZR17 tires. They are a little wider than stock, the swap took about twenty minutes and it fit like a glove.
Just be careful... with a fox body, you need to get a 93 Cobra R brake booster, and a master cylinder that will work with four wheel disk brakes. (also, on my car the e-brake cables did not match up... Ford Racing has kits)
91' Convertible, T-56, Cage, Aluminum Flywheel, Passes Smog on 87 Octane |
#9 | ||
Threads Similar to: Best Disckbrake Rear For 88 Mustang
| 98 Mustang GT 8.8 rear end | 98roush | 96-98 | 0 | August 17th, 2007 02:13 PM |
| 97 Mustang Rear End | Jammess194 | 96-98 | 5 | April 17th, 2007 06:31 PM |
| Mustang rear Trim | stonecold316 | 2005 - 2010 | 6 | April 5th, 2007 02:59 PM |
| 8.8" Mustang Rear | AtlanticBlue99 | General Tech | 22 | January 27th, 2006 11:07 PM |
