short belt size please
Old August 19th, 2006, 06:43 PM   #1
chadjones99's Avatar
chadjones99 is on a distinguished road
need size for this...........
A/C removed , Smog removed
thanks
chad
Old August 19th, 2006, 07:54 PM   #2
Anthony is on a distinguished road
ez way to measure it would be with a peice of string.
Old August 20th, 2006, 09:58 AM   #3
93Coupe's Avatar
93Coupe is on a distinguished road
I believe it's 83.5
Scott
Old August 21st, 2006, 12:04 AM   #4
well i just got a 73.5 inch and its about 2 inch to long..(funny never had that problem before !)
1986 stang ,Edelbrook intake, aluminum heads, E303 cam ,70 MM throttle body ,24lb injectors ,373 gears , 10:1 pistons set up,no cats , flowmaster mufflers , short shifter , 255 fuel pump , smog pump delete , A/C delete , Aluminum Radiator , MAF convertion
Old August 21st, 2006, 04:08 AM   #5
junknotch is on a distinguished road
I used this belt number from Napa 25-060710
Now you have to remove the tensioner and remove a pin size mold on the back of it. Then put it back on and it worked fine for me.
Old August 21st, 2006, 03:30 PM   #6
cooktheworld is on a distinguished road
on my 93 with ac pulled out i went through about 5 belts before i got the right one. just try to measure and buy a couple and take back the ones that dont fit
Old August 21st, 2006, 05:12 PM   #7
ok got a 70.5 .. to small went back to store got a 71.5 man it was tight, matter of fact i have the top bolt out of the alt , and idler off, your right about the idler i took the pin off and rolled it back down on top of belt , will run it and let it break in , then put the bolt on alt and push down on idler.
Old August 21st, 2006, 05:16 PM   #8
thanks for the help
Threads Similar to: short belt size please
What size belt nasty92LX 5.0 Mustangs 5 September 29th, 2007 04:14 PM
belt size without smog nasty92LX 5.0 Mustangs 1 April 4th, 2007 07:34 AM
Short Belt Size shadowgames81 5.0 Mustangs 2 January 25th, 2007 08:44 PM
Belt size illusionownz General Tech 0 October 20th, 2006 06:53 PM
What Size Belt ? Wallace J 5.0 Mustangs 4 September 20th, 2006 02:46 PM
