dropping rpms
Old August 19th, 2006, 07:31 PM   #1
1990 Mustang GT
rocket is on a distinguished road
dropping rpms
my '90 GT drops the rpms when idling occ, not all the time, and occ. will die because it idles so low. Usually only happens when the AC is on, if you turn it off, usually stops. Any thoughts on what would be causing this?
Old August 19th, 2006, 08:02 PM   #2
Anthony is on a distinguished road
what does it idle at, 600-800 rpms? u can bring it higher if its too low. have u checked all ur vac lines, cleaned maf, etc.
Old August 19th, 2006, 08:52 PM   #3
Vamp89's Avatar
1989 Mustang GT
Vamp89 is on a distinguished road
Could bump it up, check tps sensor, iac, etc.
Ported Saleen Vortech Intake
BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump
Hooker Super Comp Long-tube Headers
Fcam
Ported Motorsport J302 Heads
30# Injectors
1.6rr
80mm Mass Air
4:11 gears
Old August 19th, 2006, 10:49 PM   #4
vfast will become famous soon enough
I would set it a 800 then set the tps to .99 volts..get a can of seafoam... I would clean the T/B and egr as well as the maf if using a K/N filter..
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old August 20th, 2006, 10:09 AM   #5
1990 Mustang GT
well, it doesn't idle low, it just drops the rpms/volts then it bounces back up, and it does this over and over usually until I turn the a/c off. it doesn't cont. idle low. sometimes it bounces so low that it dies. could it be electical or some sensor?
Old August 21st, 2006, 01:53 AM   #6
IcantDo55 is on a distinguished road
Look for the idle setting procedure on here and try it.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old August 21st, 2006, 09:46 PM   #7
stang fanatic's Avatar
stang fanatic is on a distinguished road
http://wind.prohosting.com/hotparts/t0000004.htm
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Threads Similar to: dropping rpms
Dropping in a V8 nickp008 V6 Mustangs 24 June 9th, 2007 12:28 AM
Still dropping MSTGGT00 99-04 14 May 4th, 2007 02:55 AM
Dropping A 5.4 In built54 V6 Mustangs 17 October 8th, 2006 02:16 AM
Dropping A 460 tdurbin 5.0 Mustangs 6 September 20th, 2006 09:52 PM
dropping my car..1in..1 5/8...2in? itschristorres8 V6 Mustangs 21 August 31st, 2006 08:53 PM
