performance water pumps?
Old August 19th, 2006, 11:54 PM   #1
cdunc24's Avatar
cdunc24 is on a distinguished road
What is the advantage, if any to using these Weiand (I think) really expensive pumps? Or other types over an auto parts store pump.
Old August 20th, 2006, 12:25 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
A stock 5 liter pump will cool almost anything.
Old August 20th, 2006, 01:48 PM   #3
cdunc24's Avatar
thanks, I'll go w/ that one
Old August 20th, 2006, 09:24 PM   #4
cooktheworld is on a distinguished road
i have meziere electric pump that works great. no cooling problems since installed
Old August 21st, 2006, 01:33 PM   #5
stanginfection is on a distinguished road
The new water pumps such as the aluminum housed Wieand will flow more coolant at low rpm such as in heavy trafic or cruising. They are machined, not just rough cast so the impeler to housing clearance is much closer. I used to have cooling problems with a 351W using the crappy rebuilt unit from Napa. The Wieand solved the problem and a cheap fix considering it's only about $30 more than a rebuilt POS.
Threads Similar to: performance water pumps?
Fuel Pumps MustangMatt96GT Modular Mustangs 2 May 14th, 2007 01:54 PM
1 or 2 pumps angermgt 5.0 Mustangs 3 March 11th, 2007 11:52 PM
What pumps do I have??? duel pumps, see pics jdslyrbullitt 99-04 1 February 26th, 2007 10:16 PM
What are smog pumps? Onemanzu V6 Mustangs 9 December 13th, 2006 01:48 PM
fuel pumps CyberPrey V6 Mustangs 1 November 28th, 2006 07:26 PM
