Fuel Pump Size
Old November 11th, 2007, 08:03 PM   #1
imported_Gt_Jay's Avatar
1993 Mustang LX
N/A
imported_Gt_Jay is on a distinguished road
Send a message via Yahoo to imported_Gt_Jay
Fuel Pump Size
I have 24 lbs injectors and was wondering what size fuel pump i need.
Old November 11th, 2007, 08:04 PM   #2
The Razor's Edge
White Thunder's Avatar
get a 255
founder of the FTN Club
Old November 11th, 2007, 08:06 PM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
yeah i agree 255lph for the win
Old November 11th, 2007, 08:13 PM   #4
The Razor's Edge
i think you can run that on stock..
Old November 11th, 2007, 08:19 PM   #5
1993 Mustang LX
N/A
i'am doing a 4 to 8 conversion
Old November 11th, 2007, 08:19 PM   #6
The Razor's Edge
yeah 255 then
Old November 11th, 2007, 08:20 PM   #7
The Razor's Edge
get a fuel pressure regulator too....
Old November 11th, 2007, 08:21 PM   #8
1993 Mustang LX
N/A
what is normal psi for that set up
Old November 11th, 2007, 08:22 PM   #9
The Razor's Edge
you would have to wait for someone else to anwser that one bud....i drive a neon!!
Old November 11th, 2007, 09:34 PM   #10
jam77's Avatar
1987 Mustang GT
39 psi is stock
Old November 11th, 2007, 09:34 PM   #11
jam77's Avatar
1987 Mustang GT
I love neons!!
Old November 11th, 2007, 11:01 PM   #12
white93pony is on a distinguished road
after you get it running set the fp with the vaccum unhooked set it at about 40psi how much power you have will tell you how big a fp you need im running about 315 hp at the wheels with a 150 shot and i have a 190 lph pump no probs.
Old November 11th, 2007, 11:35 PM   #13
Wouldnt hurt to put a 255 in there though...They are the same price and it doesnt do any harm having the bigger pump in there...
Get the 255lph.
Old November 11th, 2007, 11:45 PM   #14
TurboLX's Avatar
1988 Mustang LX Turbo
No Need for a 255lph FP unless you have a forced induction application nor do you need 24lbers unless your doing an MAF
Old November 11th, 2007, 11:47 PM   #15
The Razor's Edge
srt! whot whot
Old November 12th, 2007, 12:02 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I always put the 255lph pump in. Its $5 more than the 190lph and gives you room to grow.
Threads Similar to: Fuel Pump Size
Which Size fuel Pump for This Application Speedstang302 5.0 Mustangs 6 September 11th, 2007 09:11 PM
Smog pump delete belt size ??? jam77 5.0 Mustangs 3 July 10th, 2007 05:17 AM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
Is The Inlet Size of T-Rex Fuel Pump -8an ? 92lx5oh 5.0 Mustangs 0 March 20th, 2007 03:03 PM
Belt Size? (No Smog Pump) imported_fox_body 5.0 Mustangs 3 October 18th, 2006 03:29 AM
