Top End Kit AFM or Trick Flow
I am about ready to put a top end kit on my 91 LX convertible. I like both the Trick Flow street heat and the AFM 6200 or 6500 rpm kits. Can anyone recommend which they like best. Any other recommendations?
1987 Mustang GT
I would go trick flow , I was really impressed with their heads when i pulled them out of the box
#4 | |
13.64@101mph
also the trick flow kit is basic..its rlly no big deal, the heads are good, but theres better out there.. to put it bluntly...i say build you're own top end..canfield, rhs, afr or brodix heads, custom camshaft, trick flow or holley intake, then chromemoly pushords, 1.6/1.7 rr's, lifters, springs etc... TB, inj, FP, AFPR, MAF etc...
well maybe he wants a basic build kit
13.64@101mph
well if that do the trick flow top end kit, just swap the cam for a comp or anderson ford cam, and the roller rockers, springs, and pushrods out too..and be done w/ it..
Threads Similar to: Top End Kit AFM or Trick Flow
| Trick Flow Top end kit. | Timm10221 | 5.0 Mustangs | 23 | October 17th, 2007 02:36 PM |
| trick flow | Iownastang | 5.0 Mustangs | 7 | July 6th, 2007 12:50 AM |
| gt 40 or trick flow? | 95wip | 94-95 | 8 | April 21st, 2007 10:42 PM |
| trick flow top end kit on a dss 331 | stangzilla 331 | 94-95 | 10 | March 30th, 2007 07:45 AM |
| Trick Flow | 92mustanglx | 5.0 Mustangs | 0 | September 3rd, 2006 05:13 PM |
