Injector Size
What size in injectors are stock and fuel pump????
1988 Mustang Notch
it's a bad bitch..i promise
the stock size injectors are 19# (orange), however a good upgrade is the 24# blue injectors from FMS, if u have an all bolton 302.
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] Last edited by CAMN89GT; November 14th, 2007 at 11:18 AM. |
yeah I just doing the top end, with a trick flow kit your right with that TW heads.
1990 LX hatch
I think stock fuel pump is 88lph, I'm pretty sure on that.
1988 Mustang Notch
Trickflow Street Heat Intake ...
Trickflow Twisted wedge heads Trickflow Stage 1 Cam = Trickflow Top End Kit NOW, I would do these ALONG with the TFS top end kit and you should make some pretty good power. 1) BBK 75 MM Throttle Body 2) BBK Cold Air Intake 3) C&L 73MM Mass Air Sensor 4) FMS 24 # Injectors 5) BBK Adjustable Fuel Pressure Regulator 6) 255LPH Fuel Pump.
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] |
what should the fuel pressure be set at
1988 Mustang Notch
With the mods above, 34/35 PSI. Also, how does your car sit now? Stock gear in the rear end? Any suspention mods? I would seek after you get all these mods done that you invest $120 into Lakewood 90/10s and Lakewood 50/50s and a set of slicks! Also is the car a 5spd or AOD? if 5spd, another great mod would be a PRO 5.0 shifter, if AOD, well lets leave that alone, LOL.
4 banger with aod convert into a v8, t-5 rear 3.55 stock suspention.
#9 | |
1988 Mustang Notch
Suspention: Get Lakewood 90/10s , Lakewood 50/50s , KB Subframe Connectors....
Good Idea, rollin but i'm not into darg in to circut
1988 Mustang Notch
Uh .. Are you fucking serious?
what do you mean. Road racing lot more fun.
Fastfordsoftexascc.com |
1988 Mustang Notch
No way. It's all about the adren that you get from racing!
Threads Similar to: Injector Size
| Injector Size | mmvi | V6 Mustangs | 11 | November 10th, 2007 04:11 PM |
| Suggested injector size?? | jam77 | 5.0 Mustangs | 12 | October 17th, 2007 12:40 AM |
| Injector size and MAF conversion? | Never2fasst | 5.0 Mustangs | 1 | August 28th, 2007 04:16 PM |
| Fuel injector size? | WAR-PARTY | 5.0 Mustangs | 4 | February 19th, 2007 09:50 PM |
| injector size? | 92_LX_5.0 | 5.0 Mustangs | 6 | February 11th, 2007 01:42 AM |
