Discussing EGR Delete in the 5.0 Mustangs Forum. i yanked out my egr valve and put on a block off plate and plugged ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1987 Mustang GT vert
EGR Delete
![]() 1989 Chevy Blazer 4x4 1987 Ford Mustang GT 5.0/C4 1986 Monte Carlo SS 350/350 |
im sure you have it ok... on mine i didnt have a line hooked to it to start so i just put a plate in place of the egr. if nothing reads and it seems to run the same you should be ok... i wouldnt know why not
That is funny my light is still on. Did you leave it plugged in under the hood or did you get rid of it all together??
i got rid of mine all together and no engine light came on
maybe its different on 4.6's??
whats the part number for the simulator that u put in for the check engine light
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
1990 LX hatch
Your eeciv corrects timing to compensate for the EGR, if you don't have it hooked up the Check Engine light comes on for the EGR code, but it is compensating for the EGR not opening. So I recommend leaving it with the light on, or getting a chip, or something to turn EGR function off altogether.
Sorry this is on my 90.
1987 Mustang GT
i run with mine plugged
1987 Mustang GT
I was told that when the computer throws a egr code that it just takes it completely out of the equasion. Mine throws the code but runs perfectly
1990 Mustang GT
9.39@76.09----1/8th mile
wat is the purpose of deleting the egr
to keep the exhaust gases from re-entering the air-fuel mixture in the cylinders. it keeps the combustion cleaner.
cali 5.0, i got it from ebay! actually i got both from ebay. the block off plate and the plug in EGR eliminator simulator plug. when the ecm sends a signal to the egr threw the wiring the simulator "simulates" the function of the egr as if it was still hooked up.
i just cut some sheetmetal, drilled two holes, put gasket sealer on it and painted it. (worked great) i know its kind of rig'd but it looks fine with the maroon paint.
Really cheap way to do it, but it works. |
#14 | |
Thats my way of doing things! ! ! Here is my EGR delete..... all I did was remove the EGR plate and fabricated a throttle cable bracket.... very cheap, and very effective.... ![]() Expanded view.... ![]() It really helps to free up some much needed space for intercooler piping... The only place exhaust should be going is into a turbo, not the intake! ! !
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
wow, thats looks sweet! i'm really a newbie when it comes to anything but GM. this is my first ford, and i love it. i actually enjoy driving it more than my 86 SS and i have 3 times the amount of money it IT! thats why the stang is getting the ROYAL treatment, new carpet, seat upholstery, tires and a top before i do anything else to the monte!
good job on all the fab work!
Threads Similar to: EGR Delete
| Delete | HessiaN257 | Northwest | 3 | May 18th, 2008 12:16 AM |
| IAC delete? | acmillr | 99-04 | 12 | August 1st, 2007 02:37 PM |
| A/C delete | scuzzdude2587 | 96-98 | 5 | July 27th, 2007 10:59 PM |
| PCV Delete Kit | Murderjetz | V6 Mustangs | 14 | June 17th, 2007 12:44 AM |
| PCV Delete | AtlanticBlue99 | General Tech | 3 | March 16th, 2006 05:21 PM |
