88' Vert Factory Chassis Bracing
Old November 14th, 2007, 06:42 PM   #1
mmassa's Avatar
2003 mustang gt
slow
mmassa is on a distinguished road
Can anyone help me, im attempting to reduce the body roll of my vert, i ordered a strut tower brace and a 4 point k member brace. i have solid weld in subframe connectors, i intend onreplacing the shocks and struts when i do the install of new goodies... any more ideas? btw, someone before me removed all the factory under body bracing .... if you know where i can get this let me kow
Last edited by mmassa; November 14th, 2007 at 06:44 PM. Reason: needed to add something
Old November 14th, 2007, 06:45 PM   #2
The Razor's Edge
White Thunder's Avatar
weclome to the site...someone will be along to help you with your problems....
founder of the FTN Club
Old November 14th, 2007, 06:47 PM   #3
mmassa's Avatar
2003 mustang gt
slow
thanks bud
Old November 15th, 2007, 05:42 PM   #4
mmassa's Avatar
2003 mustang gt
slow
chassis bracing
88gt convertible can someone explain to me what and where these braces go or look like
Old November 15th, 2007, 05:49 PM   #5
TurboLX's Avatar
1988 Mustang LX Turbo
i dont think there is braces because mine didnt have any ither
Old November 15th, 2007, 08:55 PM   #6
5mustang0 is on a distinguished road
you could add a cage to it that should help a lot with the flexing
Old November 15th, 2007, 09:15 PM   #7
tmoss's Avatar
tmoss is on a distinguished road
The bracing was two weak azz "V" braces with the bottom of the two Vs on the K memeber. The opposite "open" ends mounted on the bottom of the radiator brace and back to the area on the frame just below the front edge of the doors. They were hollow, long , smashed flat on the ends to bolt them up and weak. They are sitting along the wall in my garage. The other bracing had to be removed to put the subframes on and consisted of two small plates that connected the frame to the exterior kick panel area - also not substantial.
My car has Kenny Brown subframes, K-memeber brace and strut tower brace - that stuff is substantial bracing! Don't worry about the factory stuff - it's not worth it.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old November 16th, 2007, 06:44 PM   #8
sneezingfox's Avatar
sneezingfox is on a distinguished road
I agree with tmoss. Factory bracing is not worth replacing. You can benefit way more chassis stiffening by adding aftermarket parts. I purposly took off some factory bracing to get my subframes a little more flush on the bottom (made my own). I run a maximum motorsports strut tower brace (awesome! better than frpp brace), granatelli upper and lower tube style control arms. I had bbk boxed style but they did not fit eiback sway bar kit. I also have a maximum motorsports k-member brace. when I do the interior in the spring, a 6-pt cage is going in. With that alone, forget about factory peices. It will probably be more of a hinderance that will prevent you from future modifications
Old November 17th, 2007, 12:21 AM   #9
Rustbelt's Avatar
Rustbelt is on a distinguished road
my vert flexes like it was made out of paper. just by adding the strut tower brace i noticed a big diffrence. adding sub frames in the spring. my buddy is going to make a rear strut tower brace 4 me. i have no idea if it will work though.
Old November 17th, 2007, 12:25 AM   #10
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
The strut tower will make the biggest differenc next to sub frames
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Threads Similar to: 88' Vert Factory Chassis Bracing
chassis check gicantor2 5.0 Mustangs 3 May 28th, 2007 12:20 AM
chassis saver Sh0gun! The Clubhouse 6 April 26th, 2007 05:46 PM
Stiffening a Convertible Chassis jtillery 5.0 Mustangs 3 April 25th, 2007 12:30 AM
chassis-body dimensions lemon 99-04 0 September 7th, 2006 09:06 PM
90 Vert factory spring rate? TMF 5.0 Mustangs 0 August 13th, 2006 05:13 PM
