#21 |
#22 |
Supercharger!
1966 Mustang Coupe Ford Racing 5.0 HO Roller Motor/B303 Cam/1.7 RR TFS TW 205 Heads/Ceramic Coated Tri-Y Headers Edelbrock Performer RPM/Holley 650 DP 8 qrt Milodon oil pan/Griffin aluminum radiator Mallory Distributor/MSD/Holley Electric Fuel Pump 2.5" Exhaust with H pipe/2 chamber Flowmasters Auburn 3:55's rear/Aluminum drive shaft + loop SSBC disc brakes/C-4 wTCI 2800 15x6/15x7 Torque Thrust D's BFG Drag Radials Fiberglass Shelby hood/frt valance/trunk/bumpers |
#23 |
13.64@101mph
umm either way you spit it...if you plan on putting down about 400-450hp to the crank or pavement, you not going to hook with stock suspension..i say do a mild stroker and rest on suspension...get around 350 hp and be able to plant that...make it so you cant spin tires w/ ease...and you can make a stroker with low compression if you wanna go s/c...but the easiest thing to do is put a s/c ontop that stock motor, make about 270rwhp and do some more suspension stuff, add and intake, then a cam and rockers, then maybe heads down the road...you dont need it all at once..otherwise you'll see about $6-8k gone in a heartbeat too..
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
#24 |
13.64@101mph
also there have been alot of strokers with about 500-700hp that make 12/13 passes...you rlly wanna be that guy?
#25 | |
1987 ford mustang gt
well see when shes done
#26 |
13.64@101mph
i wish i had 14,000 in the past yr..if i had that...who know...prob be changed into 1/2 dollar bills and hit up the bestest titty bars!!!
#27 |
1988 lx
9.68@142
the previous owner put koni adjustaible shocks / springs on it i know i need a lil more for the suspension. ya i dont want to be that guy that cant put the power to the ground lol that would suck.
#28 |
13.64@101mph
it would, he put on just shocks and springs, well you'll need new front struts, strut tower brace, sub frame connectors, caster camber plates, rear quad delete, strong rear upper and lower control arms, thicker front and rear sway bars..and stuff like front control arms and k-member would help, also like little tricks like battery relocation would help...and better tires too
#29 |
1988 lx
9.68@142
battery relocation is easy and will be done soon. sub frame connectors coming soon
tiers and wheels are also going on before it goes on the street. i just got the engine out this morning so i want to do as much as i can before it goes back in. |
#30 |
I agree with Jordan. stroker motor (carbed in my opp.) small shot of gas. best of both worlds. good reliable transport with a good kick in the a$$ when a ricer or a chevy pisses you off.
#31 |
FUEL INJECTED
#32 |
1988 lx
9.68@142
Threads Similar to: Turbo or Supercharger?
| Turbo or Supercharger? | Thor | V6 Mustangs | 46 | September 24th, 2010 12:07 PM |
| turbo, twin turbo, or supercharger? | mustangman87 | 5.0 Mustangs | 31 | March 6th, 2010 08:35 PM |
| which one turbo or supercharger | darkcyd | General Tech | 29 | June 29th, 2007 02:48 PM |
| Supercharger, Twin Turbo, and Single Turbo | justinsstang | General Tech | 24 | March 7th, 2007 10:07 PM |
