What Kind Of Throttle Body Should I Use? 65MM or 70MM?
Old November 15th, 2007, 01:55 AM   #1
good_fellaz_76 is on a distinguished road
Send a message via AIM to good_fellaz_76 Send a message via Yahoo to good_fellaz_76
I have a 1989 mustang 5.0 i dont know which size throttle body to use to give me the best performance! My current mods are :
BBK Headers
BBK X-Pipe
SLP Mufflers
Cold Air Intake
I am maybe planning about getting an intake manifold!
Old November 15th, 2007, 03:39 AM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Get the 70mm its a little big for the mods you have now. But once you get that intake and heads down the road it will be perfect. 70 FTW
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old November 15th, 2007, 07:06 AM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Your best bet is to put that money towards an intake, the T-body will net you next to nothing at this point.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 15th, 2007, 08:11 AM   #4
if i get the 70MM without the intake will it affect my performance?
Old November 15th, 2007, 11:08 AM   #5
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I dont think it will effect it negatively it should give you some increase
Threads Similar to: What Kind Of Throttle Body Should I Use? 65MM or 70MM?
What Kind of Throttle Body Should i Get RX Bandit 2005 - 2010 11 August 21st, 2007 03:37 AM
70mm or 75mm Throttle body nHuman 96-98 6 March 1st, 2007 10:03 AM
70mm throttle body?? FaStStAnG5-0 General Tech 1 October 17th, 2006 11:21 AM
