Boring and Stroker?
hey just a teenager.. so keep that in mind.
(means low budget and daily driver pssst) got a stock 302, want to stroke it. got the money saved for just the 347 rotating assembly but its 302... do i HAVE to go to 306? i really dont need the extra boring do i? (yes i know it would be a 342 instead of 347) plus, i live in columbia SC, so do any of you know where i could get it bored out for pretty cheap around this area if i have to get it done? thanks. P.S. planning on buying the Woody's 347 gt fighter kit, anyone have any other suggestions? |
You need to know the finished size of the bore right now. I want you to run between .004-.005 piston to wall clearance. If you need to have the block honed another .001 to clean it up, you may or may not know if a 4 inch std bore piston will fall within my above guideline. The best option is to have it bored and honed with a torque plate to a final size of 4.032-4.033, since the probe pistons measure 4.028, this will leave you with the desired .004-.005 piston to wall clearance, on top of it you will need to notch the bottom of the cylinders so it will get a little messy grinding. Its not a big deal, take your time, ask me questions and I will get you squared away
The Razor's Edge
just keep on saving lil buddy and do it right...
Just a teenager... prolly means you don't have a lot of the bolt-ons??? If this is true.... do the bolt-ons first.... get a decent exhaust system, air filter, intake, brake-upgrade, suspension, transmission, then add some decent heads, cam, and a power adder. If that still isn't enough HP for you, then get the stroker...
I run 10's on street tires, and when some kid at the track asks if I have a stroker motor... I say I do.... honestly..... I have exactly 302 cubic inches.....
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
95 Mustang GT
that settles it I just watched your video I want twin turbos!!! Your car is sick...need some more/better videos to see her run....and thats more or better not more better....lol
i still need to know where i can get this done in COlumbia. i heard of a Nappa here? im not sure. anyone give me any more insight to this?
Threads Similar to: Boring and Stroker?
| Pretty Boring Day | El_Cangri | The Clubhouse | 17 | November 11th, 2007 08:59 PM |
| What a boring day... | MSO | The Clubhouse | 14 | July 5th, 2007 12:43 AM |
| boring a engine | mustangrebuilder | Classic Mustangs | 4 | March 7th, 2007 09:25 PM |
| New Fox Boring To .030 | notsoslo5.0 | 5.0 Mustangs | 8 | October 1st, 2006 03:31 PM |
| Questions On Boring My 5.0... | HORSMEN1995 | 5.0 Mustangs | 20 | September 30th, 2006 12:44 PM |
