1988 lx
9.68@142
AC Vents
i have herd about this before but i dont remember how to fix it the vents on my stang dont work is this a common problem it only blows air from the floorboard and above the dash
1988 Mustang Notch
it's a bad bitch..i promise
outside under the hood, you gotta play with the hoses, and or... the switch is bad.
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] |
It's always a loss of vacuum to the vacuum motor that is just behind and to the left of the radio in the dash - it has a yellow hose that goes to the heater/ac switch. It just pushes on and sometimes gets pulled off the motor if the switch panel has been pulled out. Other than that, you have to trace the vacuum lines back to the vacuum block.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
1988 lx
9.68@142
thanks
#5 | |
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
1988 lx
9.68@142
what is the tube coming from the top of the break booster is that a vaccume cause broke it pulling it off
Threads Similar to: AC Vents
| How to remove side vents with honey comb inserts? | BTA99GT | Visual | 4 | March 2nd, 2007 08:43 AM |
| Heating Vents Cont | dr.gonzo! | 5.0 Mustangs | 4 | November 7th, 2006 04:21 PM |
| Heating Vents | dr.gonzo! | 5.0 Mustangs | 2 | October 31st, 2006 03:01 PM |
